Go Back   CAMARO6 > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 06-27-2019, 12:37 AM   #15
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
remove the rear seat to make it easier
https://www.camaro6.com/forums/showthread.php?t=451282
Old 07-03-2019, 02:34 PM   #16
overdriv
overdriv's Avatar
Drives: 1969 Chevelle SS 2019 2SS Camaro
Do all 2SS camaros have wireless charging?
overdriv is offline   Reply With Quote
Old 07-03-2019, 03:05 PM   #17
ItsChristianInHD
ItsChristianInHD's Avatar
Drives: 2017 Camaro 2LT RS 3.6L
Yes.
ItsChristianInHD is offline   Reply With Quote
Old 07-03-2019, 04:35 PM   #18
F419sr1
F419sr1's Avatar
Drives: 2017 ZL1
I was at the dealer for the wiring updates and ask about this and was told it wouldn’t work on my 17 because the software in the car won’t support the new charger. They said they called GM about it.
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
F419sr1 is offline   Reply With Quote
Old 07-03-2019, 10:40 PM   #19
JCunningham
Drives: 2017 2SS M6
the guy in the video i posted did it. there is no software update.
Old 07-04-2019, 12:24 AM   #20
F419sr1
F419sr1's Avatar
Drives: 2017 ZL1
Didn’t make a lot os sense. The charger is hardware
Old 07-04-2019, 12:54 PM   #21
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
I think it would work, I would test it but I need to find a 2SS center console harness which already has the wireless charging pad as an upgrade.
In comparison, I bought a USB (CarPlay) module from a 2017 Camaro ‘assembly line’ unit which claimed wasn’t ever used. Fit in my 2016 and took a few hours but full functionality works and continues to work with CarPlay/Music/etc.
Bumbleboy92 is offline   Reply With Quote
Old 07-04-2019, 03:19 PM   #22
F419sr1
F419sr1's Avatar
Drives: 2017 ZL1
I’m going to try it.
Old 07-05-2019, 12:26 PM   #23
6spdhyperblue
Drives: 6th gen
The charger does NOT rely on the bcm. It functions as a stand alone. There is a status signal out wire that some cars use to show the status on the radio display. This is only a output from the charger. The only input is 12v used as power.
6spdhyperblue is offline   Reply With Quote
Old 08-07-2019, 06:49 AM   #24
jgutierrez89
Drives: 19 Chevrolet Camaro/ 15 GMC Sierra
Just like @6spdhyperblue stated the charger does not rely on the bcm. I did this upgrade on my 2015 GMC Sierra which didn't have the charger to begin with, i purchased the upgraded module that has the 3 coils and used an oem connector to plug into the charger when i built my harness wrapped it in tessa tape for the oem look ,then i tapped into the cig lighter since its on the rap circuit that way it didn't have constant power. If the camaro's are like most new gm vehicles that have the wireless charger they are going to have four wires, power, ground, status signal for the bcm to display the charging icon on the radio, and a fault signal that also goes to the bcm. But for someone who is retrofitting the only wires you need are going to be the ground and power.
https://uploads.tapatalk-cdn.com/201...83db427dd9.jpg
jgutierrez89 is offline   Reply With Quote
Old 08-07-2019, 01:08 PM   #25
JCunningham
Drives: 2017 2SS M6
your 15 doesnt have constant power? my 2000 Sierra, 2012 and 2017 Silverados all did.
Old 08-07-2019, 09:35 PM   #26
jgutierrez89
It has it but i didn't want it to be on constant power.
2017 camaro, 2lt, wireless charger
