Old 11-27-2020, 02:47 PM   #1
christisnt
MDRHRNT
Drives: 2019 Camaro SS Fireball Edition
ZL1 Plugs in Boosted SS?
What do you guys think about putting the ACDelco 41-128’s in?
I have exhausted all my options on my Procharged ‘19.
With the stock SS plugs ACDelco 41-103 (I think) i was getting spark knock at like 5k at WOT in 4 gear and up.
So I changed over to the ltr7’s and i’m getting a massive amount of misfires. It starts cutting out at the top of a gear when WOT when doing a roll.
I had them gapped at .025, then gapped them to .040 per JRE recommendations and i just cannot get rid of the misfires.
So i just ordered some ACDelco 41-128’s which go in the ZL1’s and i’m leaving them at the stock .030 gap.
christisnt is offline   Reply With Quote
Old 11-27-2020, 03:12 PM   #2
Drags1998
Drives: 15 SilveradoLTZ,162SSVert BlazerRS
Sounds like Your in over Your Head, Your TUNER should be able to ajust mixture and Timing to get You back on Track. Plugs are NOT Your only Problem!!!!
Drags1998 is offline   Reply With Quote
Old 11-27-2020, 03:29 PM   #3
christisnt
MDRHRNT
So it’s sounding like a tuning issue?
Old 11-28-2020, 04:42 AM   #4
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
do you know you cant gap iridium plugs with a regular gapper? you will destroy them.
Old 11-28-2020, 06:49 AM   #5
Drags1998
Either your tuner or the Shop that installed the blower. Theres more than just bolting on parts these days, These engines are VERY fussy when it comes to timing and mixture when you add HP parts to them! Agood tuner can set you straight, Its not cheap, BUT well worth the cost.
Old 11-29-2020, 05:26 PM   #6
christisnt
MDRHRNT
i had no idea. i figured it was just like any other old spark plug
Old 11-29-2020, 05:27 PM   #7
christisnt
MDRHRNT
definitely expensive but worth it. i changed out the plugs and it seems to be a lot better but there’s still some tuning that i think needs to be adjusted
Old 11-29-2020, 08:11 PM   #8
JCunningham
Drives: 2017 2SS M6
you probably damaged the electrode
Old 11-30-2020, 02:53 AM   #9
PeteSS2018
Drives: 2018 2SS Camaro
I'm about to install Brisk Silver racing into my boosted LT1. Will gap at .035 based on advice. Hopefully these are gonna suit, but reports I've had are all good.
2018 2SS, Hyper Blue, Australian HSV delivered
2.9L Whipple 98RON tuned 650hp/850Nm
Elite Engineering E2 Catch Can
Eibach Prokit springs
Mamo LT1 Ported TB
PeteSS2018 is offline   Reply With Quote
Old 11-30-2020, 04:54 AM   #10
Bangkok_ZL1
ZL1 Believer
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
There's more than just bolting on parts these days,...
It's become woefully obvious to me.
Bangkok_ZL1 is offline   Reply With Quote
Old 11-30-2020, 07:04 AM   #11
christisnt
MDRHRNT
Thats always a possibility, but i’m fairly gentle with spark plugs. regardless of the electrode. and the spark plugs still fired, just inconsistent. i feel like a broken plug wouldn’t fire at all. would it? i’m personally convinced that it’s tuning at this point
Old 11-30-2020, 07:31 AM   #12
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
^^^This^^^
2018 Camaro ZL1 1LE NFG; ARH 2” headers, catless mids, ARH full exhaust, Lingenfelter 18% lower pulley, ATI Harmonic Balancer, Roto-fab CAI, EE-catch can, TM ported TB, NX Lid, BMR strut tower brace. Aeroforce dual pod interceptor gauges. Tuned by Vengeance Racing!!! 644 HP @ 6250 rpm / 689 trq @ 3660 rpm
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 11-30-2020, 07:31 AM   #13
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Don't forget to check the plug wires also. I had something like that a couple years ago, switched plugs and regapped them correctly and we finally found it on the dyno. Bad plug wire that just had a little break in it.
Old 11-30-2020, 03:27 PM   #14
christisnt
MDRHRNT
i had to get rid of the stock wires. they were way to difficult to tell if they were connected properly in my opinion. i’m running the taylor wires now and they seem to sit on the plug and on the coil pretty well
advice, cel, misfire, procharged, spark plugs
