Old 12-24-2019, 09:25 PM   #1
Goohead
Horsepower whisperer
Drives: Camaro
Stud install- line hone?
Goohead is offline   Reply With Quote
Old 12-25-2019, 08:09 AM   #2
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Well, that's really close but since I don't build my own engines so I be the wrong one to ask but it seems feasible. My block was not align honed when we did the ARP studs, I know it was checked but not honed. Where do you live in Missouri? I live north of Columbia.
Old 12-25-2019, 09:06 AM   #3
L78toLT1
L78toLT1's Avatar
Drives: Hyper Blue 2016 2SS 6M
Mine wasn't line honed. My machinist, the most anal guy ever born, was surprised.
He miced the mains ten ways from Sunday. It just didn't need it. My guy said nearly all LS motors need line honing. Not sure if I just got lucky, or if there's something about the LT block that makes it more stable.
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels & brakes/GForce DS and axles/ZLE Cradle Bushings/FE4 ARB front & rear/SEMA Grill/Rotofab dry/95mm TB/Magnuson 2300/Full LT4 fuel system/JMS boost-a-pump/E85 Sensor/Ported CID heads from LME/Cammotion PD cam/Thompson Motorsports forged shortblock/catted Kooks 1 7/8 headers /JRE remote tuned
L78toLT1 is offline   Reply With Quote
Old 12-25-2019, 02:48 PM   #4
oldman
Drives: SS 6 speed of course
These are Y blocks and the studs are centered via the block buttress, most guys put the crank in and if it spings freely you are golden. Texas Speed says you MUST line hone. I did NOT remove my crank during my piston / rod rebuild.
oldman is offline   Reply With Quote
