Old 07-09-2017, 05:01 PM   #1
Goohead
Horsepower whisperer
Drives: Camaro
20x10.5 25 et? W/ 295 or 315?
Anyone have this setup? Seems most 11" rear rims are 35-38mm can anyone confirm this will fit?
From offset calf it looks like 27mm stick out more than stock 9.5"? I could have the stock offset wrong
Goohead is offline   Reply With Quote
Old 07-09-2017, 05:47 PM   #2
LSmith353
LSmith353's Avatar
Drives: 2015 Ultimate Track SS
http://www.camaro6.com/forums/showthread.php?t=495728
MRR FS01 10.5 wide with a +14 offset. To my knowledge, this is the only 10.5" setup that clears AND allows recommended negative camber for track alignment. A couple of guys have done it with a +25 offset on a 10.5 but had to grind on the strut. Search Apex.....
2015 2SS Ultimate Track Camaro
https://www.racingjunk.com/news/2014...ack-camaro-ss/
2016 2SS M6, MRC, NPP, Nav, Sunroof -- SOLD
2010 2SS/RS M6 -- SOLD
LSmith353 is offline   Reply With Quote
Old 07-09-2017, 07:08 PM   #3
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
For the rear? Or front? Square.....?
25mm in the back would look silly.
Currently. 20x11 is run with 43mm offset.(15mm poke) Sometimes lower in the 38mm offset range giving 20mm more poke than stock.
A 10.5" with 25mm will put the poke at 26mm. Too much.
I would leave the tire at 295 or 305.
BradfordCamaro is offline   Reply With Quote
Old 07-09-2017, 07:12 PM   #4
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Don't run a 315 on a 10.5" wheel.
I have a 19x11 +36 on the rear and it fits fine and does not poke past the fender.
seanblurr is offline   Reply With Quote
Old 07-09-2017, 08:29 PM   #5
LSmith353
LSmith353's Avatar
Sorry, I should have been more clear. I was only addressing the 10.5 fronts. The offset mentioned in the original post for the 11" rears will work base on the thread I referenced.
Old 07-21-2017, 08:40 PM   #6
Goohead
Drives: Camaro
Thanks for the reply guys
To clarify I was looking at
Front 9" 18 offset
Rear 10.5 25 offset
20"
I saw the thread Lsmith thanks it looks like that might work stock height and 19" worried about lowered maybe ~1 in the future and still running the same offset w/ 27mm poke out will rub?
