dave@hennessey
Old 06-15-2019, 02:37 PM   #1
Artryan
Drives: 2018 ZL1 , 2020 GMC AT4 Carbon Pro
Well, I tried...
A week or so ago, I made a post about struggling with modding my car, or keeping it stock to possibly preserve the value years down the road.
At any rate, I decided to mod it pretty soon after that thread. When I decide on something, I like to get it done asap. That's where I quickly learned that it appears the local guys here are only interested in doing enough work cover their bills I guess. I went to two local shops, left all my info and what I was looking to have done. Neither one even had the decency to call me back. I guess they don't want the work? I've been toying with just doing it myself, but I probably shouldn't.
It just pisses me off that in this day and age, you can't get people to do shit. I don't understand how people can run a successful business by not returning calls and blowing off potential customers. That seems to be a trend with virtually every business out there today that is owner/operated.
Sorry for the rant, but I figured some of you guys here could appreciate this issue. I guess on the bright side, I'll save myself a few thousand bucks.
Artryan is offline   Reply With Quote
Old 06-15-2019, 02:55 PM   #2
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
What was it you were trying to have done, if I may ask?
InFiD3ViL is offline   Reply With Quote
Old 06-15-2019, 03:14 PM   #3
Artryan
Install headers, a cam, and the stuff associated with the cam install. Possibly a new oil pump, lowering springs.
Old 06-15-2019, 07:01 PM   #4
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
The headers and lowering springs are easy and can be done with simple tools. You should do those yourself. The cam and supporting mods though, are going to be more involved and will require several specific tools such as a pushrod length checking tool and spring compressing tool. If you're doing the oil pump, look into the Katech C5R timing chain and CHE trunnion upgrade. GPIs cam kit comes with the LS2 dogbone style dampener already and your choice of lifters. They are top notch, and did my build. GPI ftw!
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 06-15-2019, 09:31 PM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
You'll also need a specific puller/installer for the balancer too.
Try and find a Z28 CAI and a set of Bilstien B6 shocks and struts.
35mm hollow DSE bar or a 32 mm JPS solid rear bar and a 1LE front bar, solid cradle bushings, Z28 UCA bushings for the rear, and your favorite brand of rear control arms/links.
Orange Krush II
Old 06-15-2019, 10:22 PM   #6
weSS1LEy
weSS1LEy
weSS1LEy's Avatar
Drives: 2015 camaro 2ss/rs/1le
Can someone find the closest LS performance shop to this guy? I would not attempt a cam install on my own. That’s just me. OP how much mechanical expertise do you have? I had my local brake and muffler shop do my headers and exhaust. Awesome shop and I have a great rapport with the lead mechanic. I then drove 7 hours to a major performance shop to have the cam done right. I have no mechanical expertise. I’m a nurse
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
weSS1LEy is offline   Reply With Quote
Old 06-15-2019, 11:13 PM   #7
hammdo
'It's an experiment'
hammdo's Avatar
7.5 hrs to GPI. Would be done right!
-Don
747 RWHP 794 RWTQ
Old 06-15-2019, 11:32 PM   #8
weSS1LEy
weSS1LEy
weSS1LEy's Avatar
Now we’re talkin!
Old 06-15-2019, 11:40 PM   #9
Sturgill_SS
Sturgill_SS's Avatar
Drives: 2010 Camaro SS
Artryan DM me. I'm close to you and have several connections
F35 Cam / LOD X-1 Manifold / SLP CAI / LS7 Lifters / 3.91 Gears / Hooker Blackheart Exhaust / TSP Headers / SLP Underdrive Pulley / MGW STS / Trunnions and all that other fun stuff....
Sturgill_SS is offline   Reply With Quote
Old 06-16-2019, 06:13 AM   #10
hill_billy
hill_billy's Avatar
Drives: 2013 Black SS M6
You should give Jared Cocanougher a call. Google is showing this as his business phone number: (888) 427-7249. I've not used this number before. So, if you don't have any luck, PM me and I'll give you his personal cell number. Just not sure he'd want his personal phone number posted.
Jared works in sales for Brian Tooley and runs his own speed shop called Race Proven Performance in Harrodsburg, less than an hour from Lex.
He can help you spec out whatever you're looking for; whether you buy it from Brian Tooley or not. His speed shop specializes in all things Camaro and Corvette. I've uploaded/attached an image of the inside of his shop (not sure where it'll show up at). These guys leave and breathe LS stuff. Jared is also an avid racer and has plenty of videos online. A cam upgrade to these guys is just another day at work.
His shop works with James Short and Shortuning, about 30 minutes from Jared's shop. James is an exceptional tuner and specializes in the LS platform. He's so busy, you can only expect to contact him by email and it might take a day or two to get a reply. But it's worth it. Info@ShorTuning.com
I'm delivering my car to Jared this Friday for a stage 3 cam upgrade (plus all the extras that go with that) and will have it back down to James for the tune on the 26th. If you go to Shortuning, he has a Dyno Dynamics dyno. And trust me, it's a heart breaker. It's a good dyno for tuning purposes, but the numbers are low.
I did a baseline at James' shop to compare to the after cam dyno tune. I can let you know how everything goes on the 27th. Let me know if you need anything. I'm only about 20 minutes from Lexington.
Jason
hill_billy is offline   Reply With Quote
Old 06-16-2019, 07:12 AM   #11
DBHWT
DBHWT's Avatar
Drives: 2013 SS 1LE
Pm'd ya
DBHWT is offline   Reply With Quote
Old 06-16-2019, 08:10 AM   #12
Chris49066SS
Drives: 2010 SS L99
Good call on that. I'm in Clarksville too, we have probably driven past one another at some point
Old 06-16-2019, 08:28 AM   #13
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
Seems to be several in Cincinnati. That’s 75 miles. RDP (DynoSteve) in northern Ohio. 360 miles. Can’t really vouch for any of them though.
Moto-Mojo is offline   Reply With Quote
Old 06-16-2019, 08:57 AM   #14
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Op.....your getting some first rate info and advice ....take advantage.
rontammy0 is offline   Reply With Quote
