10-04-2023, 03:15 PM | #1 |
Drives: Chevy Camaro ZL1 Join Date: Sep 2023
Hook me up! TRACTION
Hello yall!
I have a 2017 ZL1 and I just can't get it to hook. Not only does it not hook, it gets straight squirrely. My last car for reference was an LSA Supercharged 6.0 G8. I ran a 305/35/19 Nitto NT05R on the vehicle. It made 726rwhp and chirped the tires into 3rd, but put the power down really well for the pig that it was. I know I have shit tires on the car now. I bought it with the plain jane Nitto NT05 in a 305/30/20 and they are just flat dangerous lol. My question is should I run a Toyo 888R? I hear they are loud but hook up quite well. Should I run a 17x10 drag pack on a sticky tire? Has anyone had any luck with other setups? For reference the car makes 688rwhp/710ft with RF BigGulp, NW 103TB, CSP 2' headers all the way back, meth. PFA, thank you! |
10-04-2023, 03:55 PM | #2 | |
Drives: 24 Sliverado 1500 ZR2, 2017 ZL1 Join Date: Feb 2021
Start doing a search in the tire section. Many threads already on this.
Finally on the way to 1K.....
10-04-2023, 06:47 PM | #3 |
Disconnect 2 spark plug wires. Traction issue resolved. You're welcome!
10-04-2023, 10:58 PM | #4 | |
The conclusion from high horsepower folks here (not me but those near or past 4-digit hp levels) is that the Nitto 555RII is the best tradeoff with maximum dry traction that still preserves "normal" drivability in terms of noise and wet weather behavior.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 10-14-2023 at 05:18 PM. Reason: typos |
10-05-2023, 01:42 AM | #5 |
Drives: 22 ZL1, 18 RS3, 22 M3P Join Date: Oct 2016
I did a bunch of BMR rear suspension stuff and my car stays pretty straight now. Still on stock tires, but I'm also at stock power level.
2022 ZL1 - M6, Wrapped, Tinted, Rotofab intake, MBRP AxleBack, Lots of BMR rear suspension components
2022 Tesla Model 3 Performance 2018 Audi RS3 - Many mods & e85 Instagram - @JBsCars |
10-05-2023, 07:14 AM | #6 |
Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
I previously had the NT05s on 20x11 in the rear. They were not great. Now I have the NT555R2 in 17x10 and traction is much better. 1st gear and 2nd gear will spin at WOT on the street no matter what. 3rd is dicey. A 60-punch on the street when its HOT is doable, but still need caution. I wouldnt do that if it was below 80 degrees and/or pavement not HOT.
At this power level, i dont know that any tire is going to be great but ive never tired the 888R. The more mods i add, it doesnt get any faster on the steet, it just makes more gears unusable. The NT555R made a huge difference at the track though compared to the NT05s. I wouldnt want to run the 17x10 if i was taking hard corners though. So it probably depends on what you are after.
2017 50th Anniversary Edition | P1X Stage 2
DSX Aux Low Side | LT4 high side | Flex Fuel TooHighPsi Port Injection (installed & tuning) CircleD 3K Stall | QA1 CF Driveshaft Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear Forgestar F14 18x8 NT555G2 235/50/18 Front 10.84@131 w/4.13" pulley ??.??@??? w/3.7" pulley (installed & tuning) |
10-05-2023, 07:20 AM | #7 |
I too would suggest the BMR cradle lock out along with whatever tire you decide on. The lockout takes a few hours to instally if you have the ability and it cleans up the rear end behavior A LOT.
10-05-2023, 08:21 AM | #8 | |
10-05-2023, 08:36 AM | #9 |
10-05-2023, 08:41 AM | #10 | |
https://www.bmrsuspension.com/?page=...643&superpro=0 |
10-05-2023, 08:47 AM | #11 | |
Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
24 2SS 1LE, Riptide Blue, A10, PDR. Picked up 11/5/23, 560 miles.
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
10-05-2023, 09:10 AM | #12 |
10-05-2023, 09:52 AM | #13 |
Having FUN in the SUN...
UberTong... My quest for traction led me to install ALL of the rear end BMR stuff minus the sway bar... and YES, that along with a proper alignment REALLY helps the car plant, and track straight! Well worth the investment. As far as traction goes, i was skeptical that the R888R's would hook in 2nd, with my torque level, but i can say on most streets, with heat in the tires, spins slightly, then hooks by the top of 2nd gear...
Bad roads, or cold tires clearly dont hook even in 3rd... I went the MAX size on the rears for an extra 1" of width and I would NOT change a thing. The noise does not bother me, perhaps because the tires are competing with the over-driven blower and exhaust. Hope that helps.
10-05-2023, 10:01 AM | #14 | |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
That said, a little searching does go a long way. There are many posts about this from this year even. Certainly not required. You can do the forum however you choose.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
