Go Back   CAMARO6 > Technical Camaro Topics > Audio, Video, Bluetooth, Nav, Radar, Electronics
Old 02-14-2022, 07:26 AM   #1
TheeMajorBone
TheeMajorBone's Avatar
Drives: 2020 Cadillac CT5 Sport
How should I secure my Subwoofer box?
I am installing my subwoofer box in my 2018 2SS w/ Bose. Well versed with connections and how to tap into all necessary wiring. Simply looking for advice on how to secure the box with a couple goals in mind.
Goal is to have it secure AND easily taken out AND not add additional weight other than the sub and amp.
Subwoofer Box Dimensions are 26" x 13" x 12" (Toby Speakers Fort Worth, circa 1995)
I'll mount the Alpine & LOC amp within factory foam underneath.
2020 Cadillac CT5 Sport Summit White / Jet Black
2018 Camaro 2SS Hyper Blue
2014 Chevy SS White
2014 Silverado High Country
2008 Pontiac G8 GT - White Axel Back Solo / Volant CAI
TheeMajorBone is offline   Reply With Quote
Old 02-14-2022, 09:48 AM   #2
ctrlz
How secure do you need it?
Buy some strips of Velcro at walmart. This is in the fabric/crafts area and they have a good assortment. Just put the hook-sided stuff on the bottom of your box. That should grab the carpet enough to prevent sliding.
Old 02-16-2022, 06:54 PM   #3
KirkH
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD
Yes I have used industrial velcro to hold my custom built wood box with two 10s successfully for 5 years.
KirkH is offline   Reply With Quote
Old 02-17-2022, 09:01 AM   #4
Plasar
Drives: 2017 ZL1 Vert M6
Secured by gravity.
https://www.camaro6.com/forums/showthread.php?t=561714
Plasar is offline   Reply With Quote
Old 02-17-2022, 09:01 AM   #5
TheeMajorBone
My only concern with this is the back of the factory "floor" is not reinforced with anything. It's just carpet/padding.
I'll have to test it out to see how well it stays in place.
2014 Chevy SS White
Old 02-17-2022, 07:25 PM   #6
deathbyc4
Drives: 18 camaro 1ss 1le
take out the carpet, trace it to a piece of MDF and cut it. cut it in the middle to the same dimensions of the small board already attached to the carpet, and you have a new floor to mount things to. Add your own carpet or peel off the original carpet and use Super 70 to glue it to the new pieces.
deathbyc4 is offline   Reply With Quote
Old 05-23-2022, 03:07 PM   #7
jf12volt
Drives: chevrolet camaro
go for a ratchet tie down strap, all you need is two secure points and you are all good. i have the same box that i have moved thru a handful of cars and love it
jf12volt is offline   Reply With Quote
