03-27-2024, 10:02 PM | #14925 |
Drives: Chevrolet Camaro Join Date: Feb 2020
03-27-2024, 11:15 PM | #14926 |
Preparing for AutoX season
03-29-2024, 03:09 PM | #14927 |
Drives: 2023 Camaro SS 1LE Join Date: Apr 2019
Installed K&N CAI! 5HP increase in looks alone! HA!
Noticed coolant was low so that'll be done shortly. Last edited by sklippi2018; 03-29-2024 at 03:11 PM. Reason: now |
03-29-2024, 03:46 PM | #14928 |
Drives: 2022 LT1 Join Date: Sep 2022
Got IGLA installed. Can finally sleep a bit easier at night.
03-29-2024, 04:43 PM | #14929 |
Electrical Engineer
Drives: 2023 1SS A10 Black Join Date: Apr 2022
Parked it in my garage for the first time in 8 weeks! New engine, new fuel pump, and oddly, a new driver's window motor. It really needs a cleaning tho, they didn't try to tidy up the engine bay, at all.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
03-29-2024, 05:02 PM | #14930 |
Drives: '22 2SS 1LE Join Date: Nov 2023
Got rid of the useless 2SS wireless charger
03-29-2024, 05:32 PM | #14931 |
Drives: 2024Camaro 2SS CE Convertible Join Date: Jul 2013
03-30-2024, 07:15 AM | #14932 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Where did you get that? How easy does that come out?
I hope the 6th gen Camaro has a melodious horn trumpet. I'll tootel it at the ladies, yelling out "Hi hi." - RenegadeXR
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
03-30-2024, 07:48 AM | #14933 |
It's the ultra cheap plastic cubby from the LT / 1SS
https://www.gmpartsdirect.com/oem-pa...panel-84004284
03-30-2024, 08:09 AM | #14934 |
eBay. "Rear console" or storage cubby.
There are YouTube videos and threads here that show. Three bolts on each side tilt the console up , two Phillips screws on the inside. Hardest part is getting the rear seat cushion out of the clips. |
03-30-2024, 10:37 AM | #14935 |
Received and assembled this water deionizer for the Camaro, hoping to never again have to touch it with drying towels after a wash
We'll see how well it works, TDS here is in the low 100s, so water from the hose must not be left on the car for more than a few minutes.
03-30-2024, 12:33 PM | #14936 | |
Drives: 2023 Camaro 1SS 1LE 6MT Join Date: Nov 2023
You mean....I could not have to dry my car to avoid the spots? I use a battery leaf blower to avoid contact with the clearcoat with a light wipe to get residuals, but if I could skip that whole step that'd still save me some good time. |
03-30-2024, 01:24 PM | #14937 | |
Wife and both have Pixel 6 Pro's and neither fit in that tiny ass space. It would be semi-convenient for it to actually accept one of our phones and work. I'm contemplating hacking up one side of the console itself to make some more space and see how bad it actually looks to make the phones fit.
03-30-2024, 04:12 PM | #14938 | |
Drives: 2023/2SS/1LE/RadiantRed/A10 Join Date: Jul 2022
That’s awesome! One of my goals too. I heard from pantheorganizer (or someone else maybe) that running it after the water softener improves the life of the deionizer filter material significantly while bringing water hardness down closer to zero. I plan to run a line into the garage from the basement for it when I can finally get one. Sent from my iPhone using Tapatalk
2023/2SS/1LE/Radiant-Red/A10/Sunroof/Copper-Free-Breaks/Navigation —— Order History: 6/17/22-1100, 3/7/23-3000, TPW-4/3/23, 4/4/23-3800, 4/8/23-Delivered
