12-10-2020, 08:31 AM | #1 |
Gen6 ZL1 1LE A10 Rear Gear Ratio
Has anyone here changed to a 3.73 with their A10? If yes, what has been your experience?
'20 ZL1 1LE A10,
12-10-2020, 08:39 AM | #2 |
I don't believe you can put a 3.73 gear in your ZL1's diff. You might be able to swap in a M6 ZL1 diff which has a 3.42 gear set. Even then I would think that is still way too much gear with the A10's 4.57 1st gear...especially for your power level on street tires.
2016 NFG 1SS A8
12-10-2020, 09:14 AM | #3 | |
I know it would make 1st and 2nd gears even more difficult on the street but my idea here is to make this swap, put a true non-DOT drag slick on it and get more out the car at the strip.
'20 ZL1 1LE A10,
12-10-2020, 09:55 AM | #4 |
Yes that is correct... R/P are welded and can not be swapped. Either way A10 cars have a hard enough time launching at the drag strip with a 4.70(not 4.57) first gear and 2.85 rear even on slicks. The SS A10 cars seem to do a little better with a 2.77 rear.
2016 NFG 1SS A8
12-10-2020, 11:39 AM | #5 |
So you're saying the car won't bite with my 2.85 rear even if I put the largest drag slick that fits in the wheel well?
'20 ZL1 1LE A10,
12-10-2020, 02:15 PM | #6 |
Drives: 2017 Camaro 1SS Join Date: Aug 2016
You cannot tune your TCM (2020+ is locked, possibly forever), therefore it would be pretty foolish to try changing your differential IMO.
Plus, I agree with KingLT1 that you likely don't need more torque multiplication for launch. You have a lot of low-rpm torque with the PD-style supercharger, and a 4.70 low gear coupled to a 2.85 rear. What is the car running now at Bandimere, 60', etc? |
12-10-2020, 03:41 PM | #7 | |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
The 5spd has deep rear gears because the first gear is so tall. From my familiarity with transmissions, it has to be. Manual tranny torque capacity is an inverse of 1st gear ratio. Taller gear, more torque capacity, thus deeper rear end. Even with 3.73’s it can do 60 in first gear. That’s fricken tall. With a 4.70 first & 3.73’s you’d need one hell of a tire & suspension to get it to plant. You’d also be grabbing second at a very critical point in forward momentum. Then with he TCM... forget about it. |
12-10-2020, 04:11 PM | #8 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
I’d be worried the 1-2 shift would upset the suspension, provided it hooks, and unload it sending you possibly wall or competitor bound. Or causing mechanical breakage.
12-10-2020, 08:24 PM | #9 |
I’ve had that happen. I had my 86 GT set & it launched straight as an arrow. I built my 90 Notch & the first shake down run I came off the trans brake at 7psi & I headed straight for the 60 cone. Scared the shit out of me!
12-10-2020, 09:07 PM | #10 |
We know about "stock" LT4 Camaros that run in the 8s. What are the chances of getting one of these guys to disclose his traction-related mods? Of course I could track one of them down at a NHRA event and have a look.
'20 ZL1 1LE A10,
12-10-2020, 10:34 PM | #11 |
Ask them what they have. A stock geared ZL1 A10 could run a 30” tires & still have a deep first gear.
12-11-2020, 07:40 AM | #12 |
I will when I find out which sites they frequent. There are a bunch of LT4 drag cars and they many probably post on one or two of the same sites.
My car would not be a threat to them or a competitor because it's not stock. However, racers can understandably be a tightlipped bunch.
'20 ZL1 1LE A10,
12-11-2020, 03:36 PM | #13 |
Camaro pilot
Drives: 69 Camaro, 2014 ZL1 Join Date: Dec 2015
Doesn't putting a fat drag radial on the car (so it wont spin at all) just make the torque management kick in even harder? (pull timing etc.), so it doesn't speed you up that much?
2014 ZL1 Camaro
1969 Camaro |
12-11-2020, 04:00 PM | #14 |
No...if your tune is right torque management doesn't ever kick in.
2016 NFG 1SS A8
