TireRack
Old 10-26-2013, 10:47 PM   #1
Supreme Leader
Drives: MANual
Exclamation Took Bumper Off..2 Blocks fell
So I took my bumper off to put splitter on. And as I pulled each side on the bumper, when it came off a little wooden block painted black fell off (one on each side) what is this? I don't know if I should put it somewhere. I did not see where it fell from.
Each block was around 4 inches by 3 inches.
edit: took some pics of inside but I doubt you could see much. Also the side of the bumper there was tape if you can see.
Supreme Leader is offline   Reply With Quote
Old 10-26-2013, 11:30 PM   #2
45thAnniversary2SS
45thAnniversary2SS's Avatar
Drives: 2012 45th Anniversary 2SS LS3
Wooden blocks? Are you sure they were wood? Post some pics when you can.
I've taken my bumper off about half a dozen times and have never had any blocks fall off.
45thAnniversary2SS is offline   Reply With Quote
Old 10-26-2013, 11:33 PM   #3
dixonk
dixonk's Avatar
Drives: 2011 Audi Q7
Send a message via Skype™ to dixonk
Are you the original owner and do you have the original bumper? There shouldn't be any wooden blocks on your car. I have taken my bumper off of both my Camaros several times and have never had anything fall out.
dixonk is offline   Reply With Quote
Old 10-26-2013, 11:43 PM   #4
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS
I've never seen any blocks.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 10-27-2013, 01:00 AM   #5
DaFisch
Master Amateur Mechanic
DaFisch's Avatar
Drives: Victory Red 2011 2SS/RS
Pictures would help. I think that a body shop may have took the "easy" way out when alligning a damaged bumper and used them
DaFisch is offline   Reply With Quote
Old 10-27-2013, 10:10 AM   #6
shrinkdoc
Drives: SRT Yugo GT Super Sport with Manual
Sure they are not hard foam?
shrinkdoc is offline   Reply With Quote
Old 10-27-2013, 10:51 AM   #7
10w40
Drives: 2012 camaro
post some pics of the blocks so we can tell what they are
10w40 is offline   Reply With Quote
Old 10-27-2013, 10:54 AM   #8
LuSe4
LuSe4's Avatar
Drives: 2013 Camaro 2SS RS LS3
I have had my bumper off and there were no blocks, (wood, plastic, foam, or otherwise), that were anywhere. Someone has added these. Where were they?
-2013 Summit White over Inferno Orange 2SS RS-
-2014 White Diamond Silverado Z71 Crew Cab Short Box-
LuSe4 is offline   Reply With Quote
Old 10-27-2013, 06:26 PM   #9
Supreme Leader
Drives: MANual
Sorry I took the pics last night but forgot to upload. And I bought it barely used with no accidents.
Old 10-27-2013, 06:36 PM   #10
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
Maybe when it went up in space caught some debris up there
MARINE1991 is offline   Reply With Quote
Old 10-27-2013, 06:48 PM   #11
MBS
MBS's Avatar
Drives: 2010 rs 2lt
hmmm wood blocks , what a concept ! A new Mod !
MBS is offline   Reply With Quote
Old 10-27-2013, 06:57 PM   #12
CFD
Drives: 2SS/RS L99 BLACK
You may be able to figure out where they came from by matching the shape of the area that didn't get painted to a similarly shaped area on the bumper.
Old 10-27-2013, 07:05 PM   #13
Heisenberg
Heisenberg's Avatar
Drives: Camaro 2010
Just had my bumper off recently. No foam or wood blocks.
Heisenberg is offline   Reply With Quote
Old 10-27-2013, 07:06 PM   #14
camaro2lt
camaro2lt's Avatar
Drives: 2010 Camaro 2LT VR/RS CGM Rally's
They kind of look like shims...
camaro2lt is offline   Reply With Quote
