06-04-2023, 07:37 PM | #15 |
Drives: 2013 zl1 Join Date: Apr 2023
Ahh ok. That is manageable.. thanks
granted we lose the on the fly adjustments… but not the worst thing. Also, I do realize this is a high priced toy and don’t buy it if you can’t afford to run it. Toys do break |
06-04-2023, 08:38 PM | #16 |
Chevy Enthusiast.
Drives: 2015 Camaro ZL1 Summit White Join Date: Jan 2019
In another thread a fellow shared that BW Mfg (OE supplier) has been contacted by GM to possibly undertake a resupply. Time will tell. My dealer shared a similar comment.
Levon H. Bone Stock |
06-05-2023, 12:57 PM | #17 |
06-05-2023, 03:03 PM | #18 |
Drives: 2013 ZL1 Convertible A6 BRM Join Date: Feb 2015
Yes toys do break, however I don't think people thought that something as mundane as shocks wouldn't be available, as seemingly these parts are shared with a few Cadillac cars?
2013 ZL1 CONVERTIBLE BRM A6
OHIO |
06-05-2023, 04:10 PM | #19 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
06-08-2023, 12:23 PM | #20 |
Anthony S
Not a ZL1 but this is an option. I run these personally on my SS and they have great adjustability. they are also pretty budget friendly. I am not the only one running these so I am sure others can chime in on the ride quality aswell. If you are mostly just street and highway driving your car, these are probably your best option. Of course there are more expensive versions of coilovers, but most of them are designed with track use in mind. I believe phastek sells a magride plug that fools the system into thinking your mag ride is plugged in, so no trouble lights. But I am not 100% sure. I am just a lowly SS owner. Good luck! https://shop.bcracing-na.com/product...19701624537176
06-08-2023, 01:36 PM | #21 |
Drives: n/a Join Date: Jan 2015
I echo the previous posts of "just enjoy the car" The rears are available right now. Buy a pair even if you don't need them. You can always re-sell them if you don't use them.
ADO-580-445 I got mine from Summit, but they only have one left https://www.summitracing.com/parts/ADO-580-445 My dealer was able to order them as well two weeks ago. Also, rockauto has then in stock right now as well. https://www.rockauto.com/en/moreinfo...t=7556&jsn=914 |
06-08-2023, 05:37 PM | #22 | |
06-09-2023, 03:21 PM | #23 | |
Drives: 2006 Pontiac GTO Join Date: Jul 2015
06-11-2023, 10:38 AM | #24 | |
https://www.gmpartsdirect.com/oem-pa...RzJms9MQ%3D%3D |
06-13-2023, 12:52 AM | #25 |
Drives: 2014 ZL1 Join Date: Jun 2009
Check out Pedders XA Extreme coilovers. ~$1200 and an easy install if you have a few hand tools and jack stands. I have them on my car and they are far better than the stock mag ride IMO. 60 foot is way better at the drag strip too.
2014 ZL1 M6: Roto Fab Intake, LS3 TB, Long Tube Headers, NPP, Mild 2 Wild, JMS BAP, SMG aux pump, ID 1050X Injectors, DSX Flex Fuel Sensor, 10.5" DSX Lower Pulley, Killer Chiller, Tuned by Ted at JRE, Pedders XA Extreme coilovers, Mickey Thompson Street S/S on Weld S71s
06-13-2023, 11:26 AM | #26 | |
Drives: 2013 VR ZL1, M6 Join Date: Nov 2017
#3257 | 485whp 526wtq | K&N 63-3079 | Gates K080660HD (Green Belt) | ACDelco UPF48R | ZL1 Addons Wicker Bill | Mild2Wild
06-13-2023, 12:05 PM | #27 |
Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jun 2015
The MultiMatic shocks and springs for the 2014-15 Camaro Z/28 suffer from the same problem as the ZL1 magnetic shocks-no supply.
06-14-2023, 06:51 AM | #28 |
My rears were done yesterday and boy what a difference! The car rides so nice now. Hopefully the re-supply works out for the fronts
