05-31-2023, 08:53 AM | #1 |
Drives: '23 2SS1LE Join Date: Sep 2022
Tire choice for an abrasive track surface
First off- I know it's my fault...
Had my first track day in the SS 1LE at PittRace, which has a very abrasive surface, and managed to cord 3 of 4 brand new SC3r tires. The 2 on the passenger side were both corded on the inside, and the drivers side front corded on the outside edge. Alignment is set up with -3f/-2r camber, but going to have it checked and dialed back to -2.7/-1.7 to see if that helps with the inside edge problem. In the meantime, I need to make the next set of tires last for 3 more weekends. Considering either the Conti ECF (200TW) or the Conti EC Sport 02 (340TW). Thoughts? I know it'll be slower, but I don't care! |
05-31-2023, 09:09 AM | #2 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
I would check your toe settings first. With toe my front tires will last around 600 track miles. With 0 toe I get 1200.
05-31-2023, 09:59 AM | #3 |
Drives: Cadillac ATS-V Join Date: Feb 2023
The ECF won't be nearly as quick as SC3Rs but you'll have to work to kill them. I've got 7 days and 30+ sessions (over half of which were 30min long) on a set of ECFs on my ATS-V between NCM, Gingerman and Putnam and they've still got life in them. Probably heat cycle them out before cording them. They turn on quick, have decent pace, and are quite consistent over long sessions on sunny 90F days. I ran mine at -2.0 front camber and they did fine though I suspected they could use more, and I ran them after having Vorshlag plates installed at -3.0 and they performed even better. I think -2.5 to -3.0 front may be their sweet spot and I found 35psi hot to work great.
Shameless plug: use code FlynVIP at TrackDayTire for Buy 3 Get 1 Free Conti ECFs.
2018 Cadillac ATS-V Sedan
NCM*Putnam Park*Mid-Ohio*Gingerman*Road Atlanta*Barber |
05-31-2023, 10:47 AM | #4 |
The fact that you corded the outside of one of the front tires with -3 Camber, while cording the inside of the other makes me also suspect a toe problem.
Christian, when you run zero front toe, does it make it noticeable difference in handling or straight-line tracking (relative to the factory suggested toe setting for track driving) when doing laps? |
05-31-2023, 11:01 AM | #5 | |
I still have to lift the car up and figure out what is actually moving since I have a BMR toe rod. Last edited by Christian1LE; 05-31-2023 at 11:46 AM. |
05-31-2023, 11:42 AM | #6 | |
Drives: 2021 1SS 1LE Join Date: Nov 2020
Follow my build - https://www.camaro6.com/forums/showthread.php?t=594295
05-31-2023, 12:15 PM | #7 |
Thanks for all of the feedback! Assuming I get the alignment to zero (or near zero) toe, it sounds like the ECF will survive my planned events.
Is there any value in going with a UHP street tire just to be sure of the lifespan? I understand that both BMW and Mercedes use the Conti EC Sport at their driving schools so they shouldn't be too terrible... |
05-31-2023, 12:17 PM | #8 |
I'd choose an Endurance 200 every day and twice on Sunday compared to a 300tw+ if I was doing HPDE with any kind of regularity or sincerity.
05-31-2023, 03:54 PM | #9 |
Drives: 2020 ZLE A10, 2018 F250 Diesel Join Date: Apr 2020
Toe out - better high speed stability, turn in is a bit slower, greater inside tire wear
0 toe - high speed wobble, neutral turn in, less wear Toe in - some high speed wobble, very quick and responsive turn in, greater outside tire wear That’s been my experience with a different Motorsport, but I’m sure it applies here. Tire wear wasn’t an issue in the other sport, but stability was the biggest issue. I would just run factory spec on toe, make sure nothing is broken (check your bushings and arms for bends) and set the alignment for best tire wear. |
06-01-2023, 09:28 AM | #10 |
Went ahead and ordered the ECF. I'll have the alignment checked/corrected when the tires are mounted next week.
Thanks again for the help! |
06-02-2023, 06:20 AM | #11 |
Drives: '94 Z28+ '15 Z/28 Join Date: Jun 2009
Have you done any autocross races with the STC crew? I know there's a bunch of them with SS 1LE's. At the last race there were 4 of them there all running in F-Street.
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C 1980 Z28- resto-mod project 1979 Y84 Trans Am 1986 IROC-Z |
06-02-2023, 08:46 AM | #12 |
No, I haven't autocrossed in a long time- used to run regularly with DC Region at Fedex field.
06-02-2023, 09:55 AM | #13 |
Why not stick with the oem Supercar3's? While I don't have any personal experience with the SC3r's, I'm pretty sure you would get considerably more track miles with the SC3's vs SC3r's.
Baby Blue
