06-06-2022, 09:58 PM | #15 |
Drives: 22 ZL1 1LE A10 Join Date: Feb 2022
yet you could make more with a TB and porting. its simple, more air plus tuning (fuel) will only make more. that 723 doesnt mean much without a before, what gear, what dyno, what correction factor etc etc. you could of made 690 else where or 650 as a base run.
06-07-2022, 02:27 AM | #16 |
Drives: 22 ZL1, 18 RS3, 22 M3P Join Date: Oct 2016
Just the supercharger lid thing. That little plate inside.
2022 ZL1 - M6, Wrapped, Tinted, Rotofab intake, MBRP AxleBack, Lots of BMR rear suspension components
2022 Tesla Model 3 Performance 2018 Audi RS3 - Many mods & e85 Instagram - @JBsCars |
06-07-2022, 04:21 AM | #17 |
Drives: 2017 Camaro 1SS Join Date: Aug 2016
If you're NOT tuning it, then the regular Rotofab is the way to go, because it does not screw up the calibration. The Big Gulp version NEEDS to be tuned, because it throws off the MAF calibration with that big tube.
06-07-2022, 07:27 AM | #18 | ||
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
https://www.camaro6.com/forums/showthread.php?t=541269 In my opinion, the best bang for the buck is to remove the rain/snow blocker behind the driver's side headlight in the upper grill. This gives air a more direct path to the intake duct on the stock air box or any after market intake for that matter. This makes the car build boost a little faster and gives a little more grunt in the lower rpms. If you daily drive your car in an area with lots of snow and rain, you might want to leave the blocker in. Mine has been off for more than two years and I haven't had any issues with water intrusion--even power washing my car. See post #20 in this thread if you're interested in removing. https://www.camaro6.com/forums/showt...t=snow+blocker If you want to get real fancy, a company called Vellossa makes an intake snorkel to replace the rain/snow blocker. It's a little pricey and I don't think it provides any more performance than just removing the blocker.
06-07-2022, 08:12 AM | #19 | |
And 10 days later it made 723 wheel with HPE's 850 pkg., still with stock SC and TB, at sea level (1-2% correction), on a DynoJet, in 6th gear if I recall. I didn't add the 103mm until I added the KongX a year later.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 06-07-2022 at 08:23 AM. |
06-07-2022, 12:10 PM | #20 |
Drives: 2020 ZLE A10, 2018 F250 Diesel Join Date: Apr 2020
Idk if the rotofab adds much other than sound over the stock air box. I added one a while back and on a road course saw a slight decrease in mph on some long straight sections. But there are a lot of factors at play there. Idk. I’ve thought about going back to the stock air box.
06-07-2022, 12:19 PM | #21 |
I still think that a good LT4 starter pkg. is a 10% lower, 103mm, and a tune.
'20 ZL1 1LE A10,
06-07-2022, 02:35 PM | #22 |
Ok, and do any of the intakes make more sound than the others?
06-08-2022, 04:03 AM | #23 | |
