TireRack
Old 06-19-2023, 05:34 AM   #1
Spidey323
Drives: Chevrolet Camaro 2014
Camaro v6 exhaust size
Hey, i am wondering to change my exhaust on v6 but... still thinking should i change only axle back mufflers, delete resonators and hpipe to xpipe? and stay with 2.25"? or go full 2.5"? it change some low end torque? cause of more free flow? going for 2.5" cost more and dont know if it is worth? pls help
Spidey323 is offline   Reply With Quote
Old 06-19-2023, 06:11 AM   #2
KillboyPowerhead
Drives: 2015 Z/22
Changing the cat-back exhaust won't gain you much if any power. 2.5" pipe is a benefit (or requirement) if adding a turbo/supercharger but otherwise will only affect the sound/tone a bit. Going from H-pipe to X-pipe may also change the tone slightly, but again won't affect power. High-flow cats/cat-less downpipes will add a bit of power/torque. Cost-wise you're best off changing just the mufflers.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 06-19-2023, 10:45 AM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Totally agree here^^^
Old 08-24-2023, 03:45 PM   #4
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS
Generally you only see a performances increase with an exhaust after you get a Tune. Aftermarket Exhausts will be replacing the factory mufflers so you do technically get a performance increase via weight saving since the factory mufflers are typically heavier than the new system. If you just want to change how the exhaust sounds then an Axle Back system would be a go to choice. Just be mindful if your factory exhaust has tips or not. If your exhaust currently has tips then you can get any V6 system that also includes tips, if your Camaro doesn't have exhaust tips, and instead has the "square" tips on the rear bumper, then you would want to get a system that is also labeled as such like the MRT Version 1 exhaust is. Below is a photo showing how the square tips look like.
I am very fond of MBRP's Black Series exhaust. They are priced very aggressively, and come in a nice matte black finish.
-Trae
Sales@Phastek is offline   Reply With Quote
Old 08-29-2023, 07:04 PM   #5
xstuntman
Drives: 2012 Victory Red LFX
Not to throw feces here but in all honesty there are a ton of V6 guys that wish they hadn't touched the factory exhaust since the drone becomes unbearable with a lot of the aftermarket stuff. Those factory mufflers really do an amazing job.
xstuntman is offline   Reply With Quote
