08-31-2023, 09:12 PM | #99 | |
Drives: 2013 SS/RS, 2015 Camaro SS/RS Vert Join Date: Sep 2019
Now if/when I lose a blend door on the 2015 CE SS vert, then I will pay to have it done correctly. There won't be any hole-cutting anywhere on that car.
"Never cough into a full ashtray."
09-01-2023, 02:35 AM | #100 |
Give speed a chance
My take on this is that it's not so much of a "hack" but a maintenance "mod". As the years go by here in the desert heat the plastic gets more brittle. I'd be worried that disassembling the entire dash might result in broken clips, fasteners and stripped screw holes with annoying rattles the end result. Thanks GM (now gm)!
09-01-2023, 08:35 AM | #101 | |
Fast Cars and Old Guitars
1. Did we ever really determine if the windshield must come out or not? 2. Is the 'new' blend door the same POS that's in it now?
09-01-2023, 08:44 AM | #102 | |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
Mine is at 65k and doesn't go out in the winter. I feel like disconnecting it is the best advice for my situation. Smart, thanks for the idea!
09-01-2023, 08:51 AM | #103 | |
Drives: 2011 RS/2LT- manual Join Date: Aug 2021
09-01-2023, 08:57 AM | #104 |
To do it right the windshield does have to come out, however there’s a work around with a hacksaw/sawzall to cut the studs that necessitate the windshield removal. I’ve not seen where the blend door was definitively updated. Not a 45 said they were fixed by ‘15 but I’ve seen ‘15’s on here with the issue.
My blend door is set to cold in summer and unhooked and set to warm in winter and unhooked. That’s my solution to try and avoid the failure. If I ever do have a failure I’m going to fab a door out of aluminum and never look back.
ABM #2399 2SS/RS:SOLD
09-01-2023, 09:04 AM | #105 |
I never set it to max cold. And never needed to. But I remember reading it cycles with every key start. I can't even get shops to call me back. Apparently they don't want to F with it either!
That's probably a big part of the bill - 'we'd rather not take on the job at all but if we do, you're going pay thru the nose!'
09-01-2023, 09:11 AM | #106 | |
09-01-2023, 10:06 AM | #107 | |
Drives: 2012 Victory Red LFX Join Date: Dec 2012
Plus I built a shop, acquired lotsa tools, know all the cuss words, and will continue to work on my cars myself until I go full on horizontal. My wife says I was born to hold out.
09-01-2023, 10:12 AM | #108 |
Drives: 2SS/RS Join Date: Sep 2008
I just bought a new door and it is identical to the one that was in it. Doesn't appear to be any changes made to the door itself. If the issue was fixed, then changes was made to either the software or to the actuator itself.
09-01-2023, 10:28 AM | #109 | |
NO ONE works on my except for the following: Paint and body guy Glass guy Transmission rebuild guy Tire and Alignment guy Machine shop for an engine rebuild Basically anything that requires specialized knowledge or tools that I don't want to invest in or lack facilities to do it.
09-01-2023, 11:29 AM | #110 |
There is a company that sales a Bleend door that's made out of aluminum I believe, I don't have the link handy.
09-01-2023, 11:31 AM | #111 | |
https://www.blenddoorusa.com/product...maro-temp-door
09-01-2023, 11:53 AM | #112 | |
Give speed a chance
