08-10-2023, 12:50 AM | #1 |
Drives: 2014 Camaro SS Join Date: Nov 2011
LSA supercharger with N/A cam
So I got my car back The build is a TSP stage 4 F-35 cam ported heads. Headers rod mod intake. 510rwhp 460rwtq through the auto. I was curious has anyone ran a lsa supercharger or any supercharger or turbo with a big N/A CAM? If so did you have any issues?
2014 Camaro SS DOD/VVT delete TSP F-35 cam Chevy performance lifters CNC ported heads and intake Yank stall 510RWHP 460 RWTQ
2001 Firebird LS1 SLP lid SLP catback 2014 Camaro RS (SOLD) 2014 Camaro SS ( SOLD) 2013 Camaro ZL1 TSP headers Roto fab intake 515 RWHP (RIP) |
08-10-2023, 06:29 AM | #2 |
Richard Holdener has done tons of them on his YouTube channel. He says all cams work with forced induction.
08-11-2023, 08:48 AM | #3 | |
GPI Sales Consultant
So, what does an LSA like for camshaft - minimal overlap. Keeping the cylinder pressure in the cylinder, and not sending it out the exhaust, is critical to preserving the boost that it's capable of delivering. Intake duration can be modest, combine with a minimized overlap event that will push the intake valve close point out, which is ok as we've got pressure in the intake that will keep that port flowing and help the combo RPM. It also wants lots of exhaust duration - it's got the help of the blower to add lots of air INTO the cylinder, but it's up to the cam timing to allow all that extra charge sufficient time to evacuate before the next cycle. So, we gotta get that exhaust valve open early to help it breath and RPM well. At GPI you'll find that our PD blower cams favor plenty of exhaust duration, while keeping overlap to a minimum, which maximizes what the airflow characteristics of a mild/moderate PD blower offers. In the case of the OP, the F-35 has pretty significant overlap which is going to bleed off boost at lower engine speeds, negating some of the low end and mid-range torque an LSA is capable of. On a SBE high compression L99/LS3 that's not a horrible thing. It has a fairly late intake valve close point, which also will work pretty well. The biggest limiting factor is the exhaust valve open point, which is a fairly late. That's might work well for an NA combination that is never going over 7,000rpm, but it's not going to clear the cylinder well at higher engine speeds, and all the more so one you add boost. So, it will definitely work, but something like our GPI SC-STG3 camshaft would match the airflow needs of the combination a lol better, and improve the entire curve. Centrifugal superchargers, turbochargers, and nitrous all have their preferences as well. It doesn't mean at all that you can run a less than optimal camshaft with a given setup and have BAD results, just not OPTIMAL.
Got a question about a GPI product? Feel free to shoot me a message! |
08-12-2023, 09:18 AM | #4 |
3P171 USAF Combat Arms
Drives: 2013 SS/RS Join Date: Jul 2021
Andrew is absolutely correct (as usual).
Jannetty built mine with a 2.9L Whipple and his custom rough idle blower cam. An off the shelf NA cam I’m certain wouldn’t work as well or as efficiently.
416ci LS3/Vortech V7/Built 6L80
994.4 RWHP 793.8 RWTQ |
08-13-2023, 08:30 AM | #5 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
You've already gotten great answers.
I would just emphasize a few points. The blowers and turbos are most efficient at a certain flow and pressure. They plot it on a "Map" that can be tricky to understand the numbers going into that but easy to see if you are in the 80% efficient or 50% efficient area of the bullseye. I looked up the LSA blower before and it's impressive how they got it so efficient running on a stock or slightly mod engine with a little more boost. You would be way out like 60% I think on the LSA specifically, just a guess. Can be done but why not get the right parts to make power? Part of that is the cam. If going that route at least get a FI part that is closer to efficient. Not mentioned is tuning can be more challenging for non-experts because so much fresh gas/oxygen mix is blown past the exhaust with your overlap. If I did it with your cam I'd go turbo not blower. |
08-13-2023, 04:36 PM | #6 |
Evil Genius of Chevrolet
Andrew helped me pick out my cam. I gave him the build run down and now she's running 10.7s.
