03-23-2016, 06:40 AM | #1 |
track prep and parts required
I just picked up my 2015 Z/28 less than a month ago and I am planning on taking it to the track about 12 times this season. I have been tracking cars for 5 years and currently race SPB class in the PCA but thought the Z/28 would be fun for some HPDE days. looking for insight from you people out there that are already tracking your cars. I am not looking to modify or boost HP. simply looking for track prep tips. I see some people modify the coolant. anybody find issues with brake fluid fade? what tires are you running and are you using stock wheels? the big question is brake pads. anyone trying anything on the aftermarket?
appreciate your thoughts. |
03-23-2016, 03:38 PM | #2 |
Drives: Z/28 Join Date: Oct 2015
Brake fluid and - camber is a must, harness also. May want to get some stone guards behind the front tires if you like the paint on your quarter panels.. I also put a rag with a rubber band around the brake fluid cap, it likes to seep when under G loads.. Also installed mesh behind my grilles to keep the rubber clag out and flying objects from puncturing anything important. Stock everything else..
Im sure more will chime in if I missed anything. |
03-23-2016, 04:45 PM | #3 |
15w-50 motor oil is recommended by GM and a 70% distilled water & 30% Dexcool mix. Use a Dot 4 high temp brake fluid for sure. Make sure to "bed the brakes" according to the GM procedure before tracking. The carbon-ceramic brakes require special procedures before optimal performance is obtained. Once they are bedded properly, you will be amazed at the braking performance. Set your air pressures on the Trofeos to 28ish starting psi before tracking.
03-23-2016, 07:42 PM | #4 |
Drives: 2015 Z28 Join Date: Nov 2015
Timely thread!
I'm in the same boat so...subscribed
Go For Wand - RIP October 27, 1990
03-23-2016, 07:44 PM | #5 | |
Drives: '14 1LE Join Date: Nov 2013
03-24-2016, 06:24 AM | #6 |
ok excellent feedback. I appreciate it but of course now that leads to a few more questions.
stone guards? I have seen a few references to these. something available brand specific? oil weight: I found this interesting and will keep you guys posted on my statistics. I am a little oil crazy and send all of my samples to blackstone labs for analysis. I will be comparing weights and brands on this car over the next 4,000 miles ( I change the oil every 1000 miles max.) and will post information for everyone to see. GM procedures: I bought my car used and maybe I am missing some books or info that came with the car? I have nothing that talks about tracking the car from GM. has anyone tried aftermarket pads or just staying with stock? harnesses: absolute must! I saw some of the old threads about autocross set ups. I installed a harness bar I bought from JDP performance. what I wasn't expecting was that I am now ordering a Cobra seat. I am 6'-2" and don't fit in the stock seat with my helmet on, unless I pull the head liner. Camber: does factory set up allow you to make negative adjustment enough or do you need to invest in some camber plates? thanks again. I see a bunch of you guys are NJ, PA and VA. maybe I will see you guys at the Glen. or if anyone is interested in track events in New England let me know and I can share some info. there are now 5 tracks in New England open this season! |
03-24-2016, 06:58 AM | #7 | |
03-24-2016, 07:01 AM | #8 |
Hamfist Racing
Drives: '15 Z/28 Join Date: Nov 2014
I have two brand new OEM carbon rotors(fronts) for sale that you'll surely need sooner or later. Priced well below any dealer.
NNJR SCCA - @autoxer
03-24-2016, 07:18 AM | #9 | |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
And make sure to use the PF64 filter when using 15w50. Don't overthink other filter options, that's the one they tested to work with that oil under track conditions. And the new LT1/4's have gone to it. Leads me to believe it's a good filter. |
03-24-2016, 09:26 AM | #10 |
I use 1/16 fiberglass mesh. I install this on every car I tack, my condenser and coolers look brand new after many track days, not 1 bent fin. On the Z I had to remove the bumper to install.
Also don't forget to remove the water drain panel from under the hood extractor.. |
03-24-2016, 01:08 PM | #11 |
Drives: Z/28 Join Date: Oct 2011
Wondering the same thing. Any screen I check open area on at 1/16th is in the 40 to 60% range at best.
Seems like if the engineers went to the trouble to make the flow tie to increase airflow, the screen idea while good in theory, is counterproductive to the airflow needs in high performance driving. |
03-24-2016, 01:29 PM | #12 |
Wanna sell your Recaro seat LOL?!?!?!?!?
Orange Krush II
03-24-2016, 01:44 PM | #13 | |
03-24-2016, 01:58 PM | #14 |
Drives: 14 Z/28 #180 Join Date: Mar 2010
Change the pedals
You might want to practice Heel/Toe before your first track day. I thought I was pretty good at it until i got it some track situations and a little rain. My foot kept sliding off the brake. wish I had another 1/2 on the left of the throttle
I m going to order some of these ASAP http://www.southerncarparts.com/2010...ls-p-2927.html |
