Old 09-23-2023, 08:43 PM   #1
carlythecamaro
carlythecamaro's Avatar
Drives: 2017 Camaro SS
Question Intake and throttle body {help}
wanting to put an LT2 & 95mm throttle body on my car but I'm sure sure what boxes to choose before I purchase. if someone could help me out I would greatly appreciate it. Link below & thanks in advance.
https://gwatneyperformance.com/produ...old-126977114/
'17 SS, Texas Speed 1 7/8in long tube headers, K&N cold air intake, stock exhaust, secondary cat delete, 02 sensor delete, custom tune
carlythecamaro is offline   Reply With Quote
Old 09-23-2023, 09:32 PM   #2
Daily1LE
Daily1LE's Avatar
Drives: 2018 Camaro 1SS 1LE
If you want it all set to bolt in:
Option 1) Pretty obvious, choose the LT2 manifold.
Option 2 porting) This is optional and budget dependent, but if you want it ready to go you want the porting with 95MM TB matching.
Option 3) You need the manifold modifications. This is a must unless you plan to mod it yourself.
Option 4) You need the MAP extension harness. This is a must unless you get it elsewhere.
Option 5). Your choice here based on budget. Choose GM or Katech.
Option 6) If you chose the porting with the TB matching, you don't need this. You will have to do the bolt hole mod on the TB tho. If you didn't port with TB matching, you need this item.
2018 1SS 1LE - DSX E85 Kit | Full ARH Exhaust | RotoFab CAI | Tuned - 462HP/469TQ
Daily1LE is offline   Reply With Quote
Old 09-24-2023, 09:18 PM   #3
carlythecamaro
Smile
thank you!
Old 09-24-2023, 09:21 PM   #4
carlythecamaro
would you recommend Chevrolet or Katech as far as throttle body upgrade?
lt2 intake manifold, throttle body
