09-28-2019, 11:53 PM | #1 |
Drives: '19 ZL1-1LE Join Date: Jul 2019
ZL1 - Muffler Delete
been thinking about an exhaust. came across muffler delete. its cheap, sounds great but i feel there is more to it.
Can someone shine light on the whole "LOSS OF POWER" or "BACK PRESSURE" issue i've been reading about? What is it? and how does it affect the car? should i just get a full exhaust instead? i know cheap isnt always a good thing also, i track my car, its a 1LE. a guy at the shop doing a cage for the car said, it will make the car slower because of aero drag. by removing the muffler you create an opening for air which will slow the car down somehow... Confused on this topic expert advice is appreciated guys. thank you |
09-29-2019, 03:43 AM | #2 |
Thank you Al Oppenheiser!
Muffler deletes and catbacks can make the car louder, but do nothing for performance. There is no "back-pressure issue" with the exhaust on our cars that you will fix with a muffler delete. When you are WOT, the NPP valves open and you're straight piped. See pic below.
For the track, don't bother investing in any mods other than a driver mod (a couple HPDE events with an instructor). Save your $ for tires, brakes and gas practicing what they teach you. If your tracks have sound checks, then spend your exhaust mod $$$ on laguna pipes to pass sound. Making the car louder is not what you want at Laguna and its brethren of <100 dbA-limited tracks. re: slower w/o muffler That cage-shop guy is talking about "parachuting," a much debated and unproven concept. Here's how the theory goes: Removing the big suitcase-muffler from our cars without modifying the diffuser makes a big hole under the back of the car. The diffuser acts as a wall at the back of this hole and becomes a parachute, preventing air from exiting from under the back of car easily. Similar to driving a pickup truck with the tailgate up (vs. down) -- also much debated and I think has been proven via testing to be bogus, FWIW. What is more likely, however, is that this hole will result in the formation of an eddy, increasing air pressure under the back of the car, creating lift, and reducing net rear downforce. Such a thing, if it were to occur, could reduce rear wheel traction at high speeds and create an instability. Hard to tell without an instrumented wind-tunnel test, and AFAIK such a test hasn't been done. |
09-29-2019, 08:32 AM | #3 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
From a pure sound perspective, muffler deletes sound like complete ass. Your ZLE deserves a better sound than a rusty dump truck. Replace your muffler with a cat/axle back and x-pipe if you are going to modify the factory exhaust, don’t just delete the muffler and replace it with straight pipes. Regardless of what you do, remember that many tracks have decibel limits.
2018 Camaro ZL1 1LE NFG; ARH 2” headers, catless mids, ARH full exhaust, Lingenfelter 18% lower pulley, ATI Harmonic Balancer, Roto-fab CAI, EE-catch can, TM ported TB, NX Lid, BMR strut tower brace. Aeroforce dual pod interceptor gauges. Tuned by Vengeance Racing!!! 644 HP @ 6250 rpm / 689 trq @ 3660 rpm
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
09-29-2019, 08:52 PM | #4 | |
09-29-2019, 08:55 PM | #5 | |
love the signature btw |
09-29-2019, 10:21 PM | #6 | |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
09-29-2019, 10:56 PM | #7 |
Drives: 2013 2LT RS, 2017 ZL1 Join Date: Jan 2013
my first thought would be more about the weight balance. taking the suitcase off would make me think there would be more weight on the front reducing the rear wheel torque throughput
09-30-2019, 07:30 AM | #8 |
Drives: 2013 C6Z06 Join Date: Nov 2016
First of all a muffler delete does not sound like crap, it sounds way better than the NPP. No need to spend 2 grand on an exhaust, a muffler delete is the way to go. Just make sure where you cut the pipes that you can bolt the NPP back on if you head to a track with sound restrictions. I do think there is some aerodynamic negative, but I haven't had any issues going 158 mph at Watkins Glen or anywhere else and I am making a custom diffuser.
Datboi's comment about weight distribution is hilarious Weight reduction is a good thing and removing 20lbs from the rear doesn't negatively effect anything. |
09-30-2019, 07:59 AM | #9 |
Drives: Chevy Camaro Join Date: Jul 2019
Listen to all the 5.bros when they delete the muffler, sound like complete dookie.
09-30-2019, 08:04 AM | #10 |
Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
Yes a muffler delete also creates a lot of drone (and not the pleasant kind).
Simply do a Secondary Cat Delete and leave the rest stock.
#SAVETHEMANUALS
09-30-2019, 08:39 PM | #11 | |
Drives: ‘18 ZL1 / ‘22 ZLE Join Date: Oct 2013
From my perspective, the muffler delete sounds good. It produces drone but I can live with that. Here's mine:
09-30-2019, 09:33 PM | #12 | |
It also seems to create a lot more vibrations, things were shaking and rattling that never shaked or rattled before. I have a loud 105db Borla Atak, so I'm not afraid of a loud system, but with no muffler it sounded so cheap and so bad.
09-30-2019, 10:07 PM | #13 |
10-01-2019, 09:43 AM | #14 |
I think some of you guys need your ears calibrated to sound not $$$$$$$. Not sure I've ever heard a street car that sounded better than my buddies muffler and resonator deleted 5.bro and some loud ass GT350 I've seen around town a few times.
