Old 04-18-2015, 05:38 PM   #1
easyfame
easyfame's Avatar
Drives: 2013 Camaro LFX
Quick question about Scosche Adapter
couldn't find this answer because its probably a stupid question.
Do I NEED to wire the speaker wires from the scosche adapter to the aftermarket head unit even if I'm using the preouts for dedicated amps? Or will that give the head unit problems if i don't. I'm planning on using a 4 channel and a mono for the speakers and subs.
Thanks!
2013 1LS Black
Mods
MRT V2 Axle Back, Cold Air Inductions Intake, Vitesse Throttle Controller, 20" Voxx SS Wheels Matte Black, Blacked Out Bowtie, Side Markers, Taillight Bezels, Front Bowtie Delete, 1LE Suede Steering Wheel, Shift Knob and boot. 4-Pack Gauge Cluster, Fog Lights
easyfame is offline   Reply With Quote
Old 04-19-2015, 01:49 PM   #2
jeffa
Drives: 2014 2LT/RS Ashen Gray Metallic
Thanks!
No you don't need to connect the aftermarket unit's speaker level outputs to the Scosche harness, but you will need to connect your 4 channel amp's output to the Scosche kits harness to drive the four speakers in the car.
jeffa is offline   Reply With Quote
Old 04-19-2015, 01:59 PM   #3
LiveWire195
LiveWire195's Avatar
Drives: 2017 Camaro 1SS
LiveWire195 is offline   Reply With Quote
Old 04-19-2015, 03:48 PM   #4
easyfame
easyfame's Avatar
Wait so I does that mean I can use factory wiring? I should add that I'm replacing the speakers as well. So I take the speaker output from the amp and connect it to the scosche lines?
2013 1LS Black
Mods
Old 04-19-2015, 11:19 PM   #5
LiveWire195
Can you take a photo of your wire harness, and I'll make a diagram for you.
Old 04-19-2015, 11:40 PM   #6
easyfame
easyfame's Avatar
I would really appreciate it thank you! I'm using an Pioneer nex 4100 just to let you know
2013 1LS Black
Mods
Old 04-20-2015, 02:43 AM   #7
opossum
opossum's Avatar
Drives: 2013
Hallo,
i have changed the boston amp against the KAC-8406 - Kenwood amp. I have connected the preouts from my kenwood DNX9210BT to the new amp. I have not connected the speaker level outputs to the scosche harness. I have installed two harnesses with double chinch-connectors from headunit via middle console to the amp in the rear of the car and also one harness with chinch-connector for the active sub. Thats the Installation with scosche kit. With metra kit i have used the factory amp replacement kit from here: http://********.com/product_info.php?products_id=489 .
The scosche kit fails my tpms. Now scosche will send me a new uac-module with the newest software. They have informed me, that the newest software has not this bug. I hope, you understand my bad english language.
Best regards from Germany
opoSSum
Chevrolet Camaro - V8 - MT - 2013 - European Version - Inferno Orange/ Inferno orange - ACC Sidemarker ghosted - Dash Kit PAC RPK5-GM4101 with DNX8170DABS - Amp KAC-8406 - Sub Pioneer TS-WX110A - Rear- and Front-Camera - ACC Mail Slot Scanner RGB - Pedders Sportsryder - painted parts in engine compartment - black powder coated original rims - H & R wheel plates 20mm front and rear axle - 1 LE steering wheel - MGW Short shifter replacement - aluminum door Pins - ACS T4 Splitter - us-mirrors - ZL1 side rockers - High Wing Spoiler
opossum is offline   Reply With Quote
Old 04-21-2015, 12:18 PM   #8
easyfame
easyfame's Avatar
any luck with that diagram
2013 1LS Black
Mods
Old 04-24-2015, 09:25 PM   #9
LiveWire195
Sorry man, I just got back in from a business trip.
I'm working on it now!
Old 04-25-2015, 12:51 AM   #10
easyfame
easyfame's Avatar
Thank YOU! doing the install tomorrow
2013 1LS Black
Mods
