Old 05-13-2023, 04:18 PM   #1
Leo72793
Drives: 2011 2SS/RS
10-13 SS/RS (12-15 ZL1) Full HID projector Upgrade
Good evening all! Here is a full write up for the 2010-2013 Camaro SS/RS and 2012-2015 ZL1. Hopefully yall enjoy having brighter headlights!
There is a Download of the instructions attached as well.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
Old 05-13-2023, 04:37 PM   #2
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
Thanks for posting. Looks like the last pic link is broken? It will not show.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 05-13-2023, 07:36 PM   #3
camguynj
camguynj's Avatar
If you mean the pdf link it works for me
Old 05-13-2023, 07:51 PM   #4
SummitWhite11
Drives: 2010 2LT/RS
Yes it looks like Tapatalk is preventing the link from working. Needs to be used in an actual browser.
2010 2LT/RS
Old 05-13-2023, 08:11 PM   #5
Leo72793
Drives: 2011 2SS/RS
Yerp. Thats one reason i just use the web version now. Taptalk disabled attachments a while ago
Old 05-16-2023, 09:29 AM   #6
camguynj
camguynj's Avatar
Hiw was the light pattern (ie. did have to make any horizontal adjustment) ? Did you use the eom shutter?
Old 05-16-2023, 07:10 PM   #7
Leo72793
Drives: 2011 2SS/RS
wont know until i get the car back. the oem shutter? do you mean the high beam?
Old 05-16-2023, 09:43 PM   #8
camguynj
camguynj's Avatar
Yes, the high beam solenoid shutter mentioned in the instructions as Optional
Old 05-17-2023, 04:43 AM   #9
Leo72793
Drives: 2011 2SS/RS
I snipped my wire off the oem one, soldered it to the new one. you cant keep the oem high beam solenoid. you have to use the new one. i just chose to cut and solder vs hardwire.
Old 05-17-2023, 10:51 PM   #10
camguynj
camguynj's Avatar
Do you mean the Morimito solenoid wire connector is not compatible with the eom wire harness so you have to replace the connector with the eom connector ?
Old 05-18-2023, 06:33 PM   #11
Leo72793
Drives: 2011 2SS/RS
Yes? i think i read that right. thats my optional step. some may choose to do something else. i cut the OEM connector off and spliced it into the new high beam solenoid (after cutting the non oem connector off)
Old 05-18-2023, 07:57 PM   #12
camguynj
camguynj's Avatar
Thanks for clarifying. Guess it would have been expecting too much to have the connector be plug compatible
Old 05-20-2023, 07:20 PM   #13
Leo72793
Drives: 2011 2SS/RS
Polished up my headlights today after a light sanding at 2500 grit. Cant wait to put these things in.
Old 05-23-2023, 07:31 PM   #14
SummitWhite11
Drives: 2010 2LT/RS
Show us the finished product when you are done with everything. I have yet to order my Morimoto components yet.
2010 2LT/RS
