04-30-2023, 11:03 AM | #1 |
Drives: '18 2SSM6 Camaro ‘01C5Z06 Vet Join Date: May 2019
New Goodridge lines
Guys, need some help please.
Trying to install a set of Goodridge SS lines on my ‘18 SS. Not got very far as I have an issue. So I started on the rear and disconnected a rear hard line and rubber calliper line. Pulled the clip and removed the rubber calliper line. Then I try to start the Goodridge fitting on the hard line tube nut and all goes well but the tube nut gets tighter before the hard line flare bottoms out in the fitting! Not saying it won’t go further but are you supposed to wrench on these things to finish the install? The oem rubber line comes apart easy. Threads are M10 x 1 as far as I’m aware so no mis matches there. I just don’t wanna mess up the hard line tube nut as I have heard they are a bitch to renew. Any ideas where I’m going wrong bow: |
04-30-2023, 11:50 PM | #2 |
Drives: 17 hyper blue 2SS M6 Join Date: Mar 2018
Sounds like it might be starting to cross thread. When I installed mine I had to leave the clip out so I could get the right angle and screw it in by hand. You should not need a wrench until it's about seated, I'd check the threads and make sure it's aligned .
05-01-2023, 01:26 AM | #3 | |
I hear you about finding the angle without the clip and starting by hand. The issue is that the tube nut goes in ok by hand but goes tight before the brake tube flare hits the seat. Am I nearly there? Maybe one more turn? I checked if I messed up by re installing the OE rubber line and it goes back fine. I believe the tube nut threads are M10 x 1. But I am doubting that as I tried to run a standard M10 x 1 nut up it and it wouldnt engage. Still confused. |
05-01-2023, 10:19 AM | #4 |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
So ironically enough, I have goodridge lines on my zl1 (ordered 3 years ago), fit with 0 issues, went right on.
As of late, we have ordered 2 pairs of goodridge lines, and they have an issue where the threads bottom out before the flared taper actually seats, so there must have been a bad batch of them at some point with manufacturing defects. I'd give them a call |
05-01-2023, 10:52 AM | #5 | |
Today I managed to get an inverted flare to -3 adapter on the tube nut and it wasn’t easy but went on with a wrench just fine. So those Goodridge crimped lines could be an issue! I will check the thread depth.. |
05-01-2023, 11:36 AM | #6 |
It's not a Goodridge issue. I bought Speigler lines and had trouble with both rear flare nuts. Unless the GR and Speiglers are manufactured by the same facility. I got one to go ok with just a little bit of resistance. I confirmed the threads were ok on that one but the other one had that feeling of impending cross threading. I removed the OE flare nut and installed a new one and all was good. 2022 SS 1LE
05-01-2023, 11:41 AM | #7 |
no issues with mine but i had a shop install them lol i dont trust myself
05-01-2023, 12:00 PM | #8 | |
Hey but I haven’t finished …..gotta do the fronts yet..ouch. Could it be a case of the factory over torquing those brake line nuts just a lil bit and distorting the threads? And not a fault of the after market stuff! What sort of a bitch is it to change the tube nut on the flare? |
05-01-2023, 12:19 PM | #9 | |
05-01-2023, 12:58 PM | #10 | |
Weird how you get to feel that moment on a bad threat when it’s gonna get stuck with no return.. ouch! Will let you know when and if it all goes good! |
05-02-2023, 11:13 AM | #11 |
Drives: '16 2SS M6 Join Date: Aug 2019
I had this same thing happen on the extended rear brake line from the lift kit on my old Jeep Wagoneer. The seller said the solution was a small copper washer that fit into the flare fitting. I never got the washer and never installed the line, it's still in my tool box where I put it 20 yrs ago.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
05-03-2023, 09:23 AM | #12 | |
No way!.. Im gonna finish up at the weekend and see what happens |
05-04-2023, 12:05 PM | #13 |
My point was that Goodridge's solution was to install a small copper washer inside the flare, but I could not comment on the effectiveness of it because I didn't do it. It just gives you another avenue to pursue.
David
05-05-2023, 10:55 AM | #14 | |
See how I get on when I finish tomorrow..hopefully weather permitting! |
