01-28-2021, 10:10 PM | #1 |
8L45/8L90 teardown videos from Transmission Digest
Part 1: https://youtu.be/RUfw3lS4H-Y
Part 2: https://youtu.be/cRYw3Gx13yA Just found this very interesting education material and thought I'd share. They mention several design changes, including one to the stator support to address delayed engagement ("clunky shift") issues. My 8L90 seems to be a newer unit, because it never had that problem, even before the first flush and the custom PCM tune I'm running.
01-30-2021, 12:25 PM | #2 | |
Drives: 2018 Camaro 2SS Join Date: Jan 2021
2001 Z28 Full bolt on’s, ported 243’s, small cam, FMVB TH400 w/3,800 hard hit stall, 3.42’s. *sold* 😔
2018 SS Camaro A8 1LE replica wheels, bone stock otherwise 2008 F150 Daily driver 2002 Heritage Softail Classic 1.5 inch lower progressive rear springs/monotube fronts, 13" apes, 21" front mammoth spoked wheel, SE 10.5 cr heads, SE 264 cams, Mikuni HSR 42 flatslide carb, V&H pipes |
01-30-2021, 01:04 PM | #3 | |
Most likely no programmers at GM work on refining this transmission anymore, they seem to be running down the clock and hoping for a low warranty concern rate. You will have better luck with an aftermarket tune once your extended warranty expires, my (impeccable) TCM tune is from Jannetty and I know there are several other reputable tuners as well who have the 8L90 figured out.
01-30-2021, 01:33 PM | #4 | |
I would be interested in comparing my tcm calibration to another current version. Should be no harm in just downloading my tune to my laptop as far as warranty purposes go right?
01-30-2021, 02:11 PM | #5 |
Drives: 2016 Camaro SS 2017 Yukon Denali Join Date: Jan 2020
The tech needs to do the clutch relearn procedure correctly. Between the relearn and the fluid flush the 8spds in both my 2016 camaro and 2017 Yukon work very well.
