01-14-2021, 11:06 PM | #1 |
Drives: Chevrolet Camaro Join Date: Jan 2021
Valve rattle sound
So I'm working on breaking in my 2021 LT1 (just changed oil at 500ish miles today), and I heard what sounded like valve rattle while I was pushing on it a little.
Basically I was doing a 2nd gear pull and running it up semi-aggressively (1/2 peddleish) to about 4500 rpm then letting off. When I was starting to let off the transmission shifted and for a second I hear what sounded like valve rattle. I did this 3 times and it happened all 3 times. I run Costco 93 and/or Shell 93 in the car so hopefully I don't have low octane/bad gas. Normal driving it runs fine and has plenty of pep. So since I'm new to the car I wanted to know if others have experienced anything similar with these cars, etc. Only thing else I think it could be is the DI pump when I let off the gas.. but that is just a pure guess.. b/c it sounds like valve rattle. FYI: In high school I had an 86 trans am with an engine my father built that was really sensitive to octane.. with that car I could tell you what stations had the best gas... wondering if this car is similar.. Thoughts/experiences? Thanks |
01-15-2021, 06:13 AM | #2 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
If you get an OBD2 plugin module you can monitor the KS to see if it is an octane issue.
https://www.amazon.com/Veepeak-OBDCh...o%2C296&sr=8-6
01-15-2021, 06:25 AM | #3 |
Drives: Fast if no one's looking Join Date: Aug 2019
Valve rattle? Might be the valve spring issue. There was a batch of bad valve springs in the LT1s that have been breaking within about 500 miles of new. May want to bring it to the dealer.
01-15-2021, 06:42 AM | #4 |
That’s what I’m thinking too. Maybe a valve spring that is failing.
01-15-2021, 08:16 AM | #5 |
Sorry, when I say valves rattle I’m trying to say pre-ignition(I guess valve rattle is an old school phrase I picked up from my father). What is strange is that it is only doing it when I go over 4000 rpm and start to let up on the gas peddle.
Thx for the feedback. |
01-15-2021, 09:31 AM | #6 |
If you can Gray, run 93 octane gasoline in your LT1. That is, if you don’t. I use Shell V-power in my ZL1 and used it in my long gone 2016 2SS. It is rated 93 octane and our big V8s love it!
01-15-2021, 09:33 AM | #7 |
Hot Camaro
Do you have the performance exhaust (NPP)? There used to be an issue where the valves in the bypass pipes would start to rattle (but that should have largely been repaired in the more recent cars).
01-15-2021, 10:41 AM | #8 | |
Thanks |
01-15-2021, 10:42 AM | #9 | |
Maybe I got a bad batch of gas... Thanks |
01-15-2021, 10:42 AM | #10 | |
Hot Camaro
01-15-2021, 11:22 AM | #11 | |
I think there were some other threads on people getting used to the start up sound of a direct injection engine, which I guess comes off as "metallic" to some people. |
01-15-2021, 11:46 AM | #12 | |
01-15-2021, 11:49 AM | #13 |
Ok went for another test run and it did not do I it 3 out of the 4 times.
I think I got some low octane gas in it from a shell station (it is half Costco and half shell in the tank now) It wasn’t doing it when I only had Costco gas. Thanks everyone for the replies/suggestions. This car is new to me and I’m learning it’s characteristics... so GM wasn’t kidding when they say use 93 octane |
01-15-2021, 11:52 AM | #14 | |
Hot Camaro
