10-10-2019, 12:32 PM | #99 | |
but my 2016 got totalled a couple of weeks ago and I bought a 2019. the 2019 wiring is different in the upper map light area. So I removed the console and tapped the power from the power port on the console. Worked perfect and honestly easier to get your hands in there to do it.
2020 Range Rover Sport HSE P525 Supercharged 5.0 - Firenze Red - 9012 wheels
SOLD 2019 Camaro SS -Wrapped in Matte Magnectic Black - Anderson Carbon Hood and Rear Spoiler – Ikon front spoiler – OEM ZL1 Side Rockers - ZL1 Addons Diffuser - BMR 1.0” Lowering Springs - MRR 228 Wheels 20x10 and 20x11 RIP 2016 Camaro SS https://www.camaro6.com/forums/showthread.php?t=565453 SOLD 2010 Camaro SS Featured in GM High Tech Performance and Camaro Now Magazines - http://www.superchevy.com/features/g...of-perfection/ |
10-11-2019, 11:33 AM | #100 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Anyone have a wiring schematic for 2019 models to identify which wire is the switched power for airbag light? As mentioned above the IS NO purple/white wire on 2019.
10-14-2019, 07:56 PM | #101 |
Finally gave up and lifted the center console (6 bolts). Having done both now, I can say it was 1,000 times easier doing the center console than the overhead. Should have done that to start with.
I now have the detector on switched power. |
04-25-2021, 04:26 PM | #102 | |
Drives: Chevrolet Camaro ZL1 Join Date: Nov 2019
On the Map Light: BLACK is GROUND and the WHITE w/Brown Stripe provides the POSITIVE 12V. |
04-25-2021, 08:26 PM | #103 | |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
This is that witty and clever statement that makes you chuckle.
04-26-2021, 07:05 PM | #104 |
Drives: 2018 2ss redline Join Date: Sep 2019
i ended up doing this, too.
i tried at the overhead light, then down at the control box in passenger footwell. the reasonably accessible ones would shut off my detector (uniden R3) when there was wheelspin. the console tap was easy & reliable. quite simply it was just tapping the power outlet (cigarette lighter hole). |
06-25-2021, 11:47 PM | #105 |
Drives: 2019 Camaro 3LT Join Date: Jun 2021
