TireRack
Old 12-01-2020, 10:10 AM   #1
booker3201
Drives: 2010 Camaro SS
Dash Pad removal 2010 Camaro 2SS
I have a 2010 Camaro 2SS that the AC evaporator is leaking. I have disassembled the dash and taken all of the screws that I can think of to try and remove it but it is holding tight on the passenger side. Any ideas?
Do the plastic air ducts under the dash pad come out with the dash pad? I disconnected the side ducts.
booker3201 is offline   Reply With Quote
Old 12-01-2020, 10:22 AM   #2
gtstorey
The HUD installation instructions should get you there.
https://www.camaro5.com/forums/showt...&highlight=hud
Old 12-01-2020, 01:18 PM   #3
booker3201
Gtstorey!!!!!!!!! Thank you so much. I missed taking out the bolts to the airbag.
I now have the dash out.
Old 06-11-2021, 01:14 PM   #4
jimrhodes
Drives: chevrolet camaro
Originally Posted by booker3201 View Post
I have a 2010 Camaro 2SS that the AC evaporator is leaking. I have disassembled the dash and taken all of the screws that I can think of to try and remove it but it is holding tight on the passenger side. Any ideas? Use essayontime to describe them better
Hey, I just found this thread. How are you? Do you have any photos of your Camaro to share here?
jimrhodes is offline   Reply With Quote
Old 06-12-2021, 10:56 AM   #5
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
to get the evaporator out you have to get the bar out. while i was in there i would replace the heater core and the blend door.
normally you have to remove the windshield but there is a way to do it that avoids that.
i used a small air hack saw anything that you can cut the extra length off the bolts with will work.
https://www.amazon.com/ACDelco-15-51...s%2C182&sr=8-1
https://www.amazon.com/Spectra-Premi...evrolet+Camaro
OR
https://www.amazon.com/ACDelco-15-63...evrolet+Camaro
lemontwist is offline   Reply With Quote
