12-10-2022, 10:19 AM | #1 |
Drives: 2023 Camaro ZL1 Join Date: Sep 2022
93 Tune + Ported TB + Upper Pulley
Are these mods good to do? Will it over heat if I add the pulley? I just do not want to do flex fuel because the inconvenience of mixing E and 93
KINGPIN
12-10-2022, 10:26 AM | #2 |
Drives: 18 ZL1 - M6 Join Date: Mar 2019
Whose doing the tune?
12-10-2022, 10:32 AM | #3 |
KINGPIN
12-10-2022, 11:43 AM | #4 |
Not the best way to go IMO. Ported blower, 95mm TB, and E85 would be a much better setup, allow much more timing, and make a lot less heat. Just my 2 cents of course.
12-10-2022, 12:03 PM | #5 |
Should be fine if all you're looking for is a modest increase in power.
12-10-2022, 04:04 PM | #6 |
Drives: 22 ZL1, 18 RS3, 22 M3P Join Date: Oct 2016
What else do you need to run that setup safely?
2022 ZL1 - M6, Wrapped, Tinted, Rotofab intake, MBRP AxleBack, Lots of BMR rear suspension components
2022 Tesla Model 3 Performance 2018 Audi RS3 - Many mods & e85 Instagram - @JBsCars |
12-10-2022, 04:11 PM | #7 |
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
The problem is you'll be creating a lot of heat in that situation by swapping out the pulley. When you create all that extra heat you can't run as much timing which is where the power gains come from. 93 and a pulley is just not ideal on an otherwise OE setup.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% Pulley, NGK HR7 Ruthenium spark plugs, Katech Oil Pump, LME tensioner, DOD delete, Cam, MPI lid, Soler ported 87mm (91mm effective) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, Borla X pipe, AFe NPP exhaust, Black Widow Angry Housewife/ Venom 250 mufflers, BMR engine mounts, Banks iDash, Lithium Battery, Course Motorsports phone mount, AEM X- Series, HP Tuners, JMS, E85, 13.6 psi
737 HP/ 779 TQ |
12-10-2022, 04:42 PM | #8 | |
12-10-2022, 04:51 PM | #9 |
What would that make on an otherwise stock car + intake? Like 630whp?
12-10-2022, 05:30 PM | #10 |
It's really not that much extra heat as long as the pulley selection is reasonable. A 9.45 lower would need some cooling upgrades.
12-10-2022, 05:32 PM | #11 |
I don't disagree that E blend would be ideal but he doesn't want to fool with blending so...I think what he was recommended is very safe and affordable too.
12-10-2022, 05:41 PM | #12 |
A 9.06 requires 94 or 95 octane to run reliably without knock. At least it does in California. I can't speak for other states but out here the fuel available at pumps is ATROCIOUS which in turn limits the amount of pulley size you can run before you are getting the OE blower too hot to the point where you are creating power loss.
737 HP/ 779 TQ |
12-10-2022, 05:56 PM | #13 | |
12-10-2022, 07:07 PM | #14 |
Even if you don’t mess with E, the ported blower + 95mm TB combo is better than a pulley + ported TB. Blower efficiency is higher and IATs are lower.
