10-29-2021, 07:04 PM | #1 |
Drives: 2022 Camaro ZL1 Join Date: Aug 2012
Copper free brake option 2022
I am going to be ordering a 22 ZL1 and was wondering if anyone knows if the copper free option is supposed to be less dust than the std pads
10-29-2021, 07:32 PM | #2 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Less dust? I'll say no. The copper in the pads was added to help dissipate the heat.
11-01-2021, 10:24 AM | #3 |
Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
I hear the 'copper free' pads don't stop as well as the regular pads.
#SAVETHEMANUALS
11-01-2021, 10:42 AM | #4 |
Drives: 2022 ZLE 6M Join Date: Jun 2021
This option is mandatory for California & Washington and was only added to be able to sell the ZL1/ZLE there again..
https://www.caranddriver.com/news/a3...ia-washington/ |
11-01-2021, 12:44 PM | #5 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Exactly the opposite. If you order the 'copper-free' you are getting the BW5 brakes. In multiple articles, it's mentioned Cadillac tested 60 compounds to get a pad that could handle ~800 laps on track. It's a Brembo pad...not a Ferodo. I haven't seen anyone post that has that option yet. Hope they post pics of the caliper/rotor. https://www.brembo.com/en/company/ne...ke-with-brembo
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
11-01-2021, 01:17 PM | #6 |
Drives: '22 Summit White ZL1 A10 Join Date: Aug 2019
Nothing more than a different pad......copper free.......
https://static.nhtsa.gov/odi/tsbs/20...86096-9999.pdf https://thebrakereport.com/copper-fr...for-22-camaro/ Last edited by Firecaptain; 11-01-2021 at 01:30 PM. |
11-01-2021, 01:53 PM | #7 | |
Drives: 2022 Wild Cherry ZL1 1LE Join Date: Mar 2021
Question : To make a Camaro compliant with the Copper Free legislation, is it just a matter of changing the brake pads? In order to maintain the same braking performance, the brake components have to grow in size and therefore, brake pads compliant with copper free legislation will not fit on Camaro models with traditional copper-containing linings. Question : Is it possible to make a vehicle produced with copper-containing linings compliant with the copper free regulation? To upgrade a Camaro model previously produced with copper-containing linings to be compliant with copper free legislation, it will be necessary to replace, pads, rotors, calipers, brake shields and in most cases, a new EBCM calibration will also be required. For Camaro models that offer components that are compliant to the new copper free legislation, the cost to upgrade the brake system will range between $2,000 - $7,000, depending on model. Geoff |
11-01-2021, 08:23 PM | #8 | |
Not what has been reported by others... There was an earlier thread on this where someone went digging and discovered it's the same brake as the BW5. https://www.camaro6.com/forums/showp...81&postcount=7 To be clear...the PDF you posted even says, it's not the standard brake with a different pad. It's a larger rotor/caliper and pad.
2017 HBM SS 1LE
11-01-2021, 09:29 PM | #9 |
Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
Hopefully, aftermarket pads with copper will be available.
11-02-2021, 10:49 AM | #10 | |||
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
RPO "BCD" is for the brake pads. For the Camaro, when you order "BCD" you automatically have to get/have "J6H".
"J6H" is the 390/365 (ZL1/1LE) rotor and caliper system. From a dealer service bulletin on 2022MY Camaro and copper-free brakes: Quote:
The description of "BCD" from the order official order guide: Quote:
>"2" is directed at 2SS as a note to "available". >"3" is directed at ZL1 as a note to "available". https://www.gmfleetorderguide.com/NA...page=6&butID=3 Short and skinny: on a 2022MY Camaro, if you check the "BCD" option on an SS or ZL1, you will get the 390mm/365mm system with copper-free pads. |
11-02-2021, 12:08 PM | #11 | |
Geoff |
11-02-2021, 12:46 PM | #12 | ||
*I think this is why the LT 1LE package/heavy-duty package option of LT's are listed to not be able to be compliant - GM likely needed a re-calibration and the business case (sales volume) didn't make sense. That or there is a capability issue with just swapping to the copper-free pads and track performance. |
11-02-2021, 01:20 PM | #13 |
Thanks!
11-04-2021, 01:08 PM | #14 | |
Drives: 22 Camaro ZLE Join Date: Nov 2021
I ordered the copper free brakes because this is what i was told too and they said it should be better than standard when tracking the vehicle. when it gets built/delivered ill take a few pictures of the them.
2022 Camaro ZL1 1LE
Built 12/7/2021 |
