Old 06-03-2017, 11:37 PM   #1
thiwho
Drives: 2012 Camaro 2SS/RS
Tour, Sport button
I have a 2012 2SS/RS and I have read that the year after mine they came with a mode selector switch that would let you change the driving stile from tour, sport modes. My question is that did it come on a later module was there changes made to the ECM, BCM ect. if there wasn't would the switch work in mine?
thiwho is offline   Reply With Quote
Old 06-03-2017, 11:49 PM   #2
warnerwh
Drives: 2013 Camaro 2SS/RS
I have a 2013 2SS/RS and all I have is the standard Stabiltrak and traction control. The ZL1 probably has touring and sport with the magnetic ride control but I don't know for a fact. They can be disabled by holding the button down for 7 seconds and will turn back on with one push of the button.
warnerwh is offline   Reply With Quote
Old 06-04-2017, 12:24 AM   #3
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
Originally Posted by warnerwh View Post
The ZL1 has touring and sport with the magnetic ride control. They can be disabled by holding the button down for 7 seconds and will turn back on with one push of the button.
You are correct...The TC button also opens up PTM's (performance traction modes 5 total) in the DIC...I don't not believe that the OP's car has magnetic ride control...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 06-04-2017, 12:26 AM   #4
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
The button your are referring to is in the ZL1. Those cars have magnetic ride as said above, so their suspension can be adjusted. The SS suspension can not, so we only have one button which controls stabilitrak and traction control. Pressing once will lower traction control, twice quickly will turn on stabilitrak competitive mode which lowers stabilitrac and holding for 7 seconds turns both off completely. This is just my understanding, so take it with a grain of salt
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 06-04-2017, 12:29 AM   #5
thiwho
O ok thanks for the info I thanks y'all for the info
