dave@hennessey
Old 11-10-2010, 09:35 AM   #29
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Originally Posted by Cmlloveless View Post
Ok so this video makes it very easy looking, BUT, that top bolt of the 3 in a row on the inside is a PITA!! It is not that easy to get at with a ratchet or bolt driver! those 2 bolts (one on driver side, one on passenger side) took me longer to get off than the rest of the bolts combined!!
Yep, LOL I edited out a few choice words caught on camera while trying to get those top bolts inside the fender....
I think if you listen you can hear me say "that sux" after getting one of them off...
Well done!
Old 11-10-2010, 11:32 AM   #30
Chrisrp454
Chrisrp454's Avatar
Drives: 2010 ABM 2SS/RS M6, 98Z28 M6
I followed the old thread and had the front wheels off, it was pretty easy.
http://www.camaro5.com/forums/showthread.php?t=64375
Always Remember! Rest in Peace Brothers
9/11/2001. And thanks to all those who defend and serve!
Ordered 5/23/2009
3400 with TPW of 08/03/09
3800 8/11/2009
Arrived 8/21/2009 2SS/RS/Aqua Blue/Grey Interior
Chrisrp454 is offline   Reply With Quote
Old 11-10-2010, 12:44 PM   #31
f5journal
Senior Camaro Fanatic
f5journal's Avatar
Drives: 2011 SS/RS manual - White
Originally Posted by mbrusco103 View Post
I'll try to remember when I get home .. maybe there not called torx screws but they are the screws that are on the left and right of the hood latch(not hinge sorry)that need the special T-something screwdriver head they are the only ones under the hood that are visible shouldn't be hard to find them
OK gotcha...yes those would mess things up
f5journal is offline   Reply With Quote
Old 11-10-2010, 01:08 PM   #32
GTAHVIT
Blessed
GTAHVIT's Avatar
it is much easier to take off the front wheels, no doubt.
Old 11-10-2010, 05:19 PM   #33
Gonzo
Gonzo's Avatar
Drives: 2011 Camaro 2SS/RS IBM 6M
Perfect timing on finding this thread. I am getting my grille painted and should be ready for install by this weekend! Thanks for doing this.
I am also impressed with your ability to work wth one hand while holding a video camera.
2011 Camaro 2SS/RS 6M IBM
Gonzo is offline   Reply With Quote
Old 11-12-2010, 10:15 PM   #34
Blacknight11
Blacknight11's Avatar
Drives: 2011 Black 2SS/RS
Uneven Hood
Ok, I dont know what to do. After installing my grill I still cannot get my hood even with the rest of the front end. I played with the screws discussed above but still cannot get the hood even with the front end. Any suggestions??
Blacknight11 is offline   Reply With Quote
Old 11-13-2010, 12:27 PM   #35
wrbear
Drives: 2010, 2SS, IOM/CGM Stripes, 4/24/10
I did mine and have a pic of the torque screws
I've attached a picture with the 2 rubber torque screws (in yellow circles):
Hand turn these. Hope this helps! oh and the other circled items were to remove the top plate only.
wrbear is offline   Reply With Quote
Old 11-13-2010, 12:36 PM   #36
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
You are not the only one with this problem... I've seen it on a couple other cars this happened to and nothing seemed to help...(Nine Ball and DaHose) adjusting the hood stop screws probably will not work or just make your hood hard to close...
I wish I had a solution but we saw no real adjustment... I even mentioned this to the shop who removed mine... wanted to make sure they knew it was perfectly lined up BEFORE they removed it.
Hopefully someone will chime in w/ a fix for this...
Old 11-13-2010, 12:43 PM   #37
wrbear
Hmm...There are 2 other screws on the top. Not sure if these are the torque screws mentioned above. You can see 2 other screws on the top next to the locking latch. They seem to drop down to a tab on the body. These look adjustable also. My experience was that the 2 rubber stops did keep the hood from dropping flush on my re-install. I did not adjust the other 2...hope the pic helps for future cussing and discussing.
Old 11-27-2010, 11:32 PM   #38
Inuyashas_Brother
Inuyashas_Brother's Avatar
Drives: '10 Camaro LS - M6
Inuyashas_Brother is offline   Reply With Quote
Old 11-28-2010, 08:35 AM   #39
afireinside
Firefighter/Medic
Drives: 2010 Camaro 1SS LS3 IOM, 2008 Z71
I used a REAAAAAALY long maybe 16" extension, that brought the ratchet out into the wheel well so your not in such a tight area took me about 20 seconds for one top bolt
Mods: LSR Sway Bars, LSR Short throw shifter, MPD1 spoiler, Heritage Grille, 5% Limo tint
afireinside is offline   Reply With Quote
Old 11-28-2010, 11:29 AM   #40
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
Great DIY
RJT, 2SS/RS, M6, Black Int, Sunroof.
(Click above image to learn about UpstateC5)
daphatgrant is offline   Reply With Quote
Old 11-28-2010, 12:30 PM   #41
GTAHVIT
Blessed
GTAHVIT's Avatar
Well the truth is I cheated and used the air ratchet for one side. but I wanted to prove that it could be done with hand tools. never thought of using an extension that long though.... good call.
Originally Posted by daphatgrant View Post
Great DIY
Thanks! Hope it helps.
Old 11-28-2010, 12:38 PM   #42
midnighter
Drives: nothing
Good video. In May I diy replaced my front bumper cover. I used a youtube video where they removed the front bumper cover to change the regular headlights to halo RS lights on a synergy 1LT. It helped me tremendiously because there are a lot of fasteners that I wouldn't have figured out are there.
DIY : Install headers on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 70 06-25-2020 06:40 PM
Camaro Heritage Grill DIY install (now with official GM install instructions). vuduman67 Camaro DIY & HOW-TO instructions & discussions 216 12-03-2014 05:18 PM
Bowtie Modification for the Heritage Grille with SS emblem cerberus Cosmetics and Lighting Modification Discussions 19 11-08-2011 08:26 AM
Heritage Grille install - How tough is it? IndyDave Cosmetics and Lighting Modification Discussions 10 04-03-2010 05:18 PM
