08-01-2019, 08:06 PM | #1 |
Drives: 2016 2SS Join Date: Nov 2011
A8 Quit Today
I was cruising at 60 mph in D and rpm spiked, I let off throttle, rpm settled, pressed throttle and nothing. I coasted into parking lot, popped hood, checked underneath-no fluid, nothing in engine bay. I ran diagnostics on Dash Command and no codes. 15,100 miles on car. I checked trans temp - 150 deg. Turned car off, started car and tried D, R, and manual. No go...
Any suggestions??? Ugh!
Who Dares...Wins |
08-01-2019, 08:19 PM | #2 |
Thank you Al Oppenheiser!
My first guess would be that the pump failed (broken chain?), but I would expect that should throw a code.
08-01-2019, 08:48 PM | #3 |
Drives: SS 6 speed of course Join Date: Jan 2016
Is it making noise, maybe a shaft failed. bummer these A8 pretty strong.
08-01-2019, 08:59 PM | #4 |
I’ll leave this here, just in case...!
https://mxamotorsports.com/product/m...ho-spec-build/
08-01-2019, 09:00 PM | #5 |
No noise, a bit of a shudder then it quit.
Who Dares...Wins |
08-01-2019, 09:02 PM | #6 | |
Who Dares...Wins |
08-01-2019, 09:30 PM | #7 |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
My crapped out of me 2 years ago...started with no shifting out of 1 st gear on the way to the dealer. I literally pulled into the dealers garage bays, they couldn't get it into D or R, $3000k in parts and labor that GM paid under warranty, basically was rebuilt.
2SS Camaro, Garnet Red, Adrenaline Red, NPP, MRC, A8, 5 Split Spoke Bright Silver Wheels (56W)
1100 Status - 7/24/15 (Ordered) 3800 Status - 10/13/15 (Built) 6000 Status - 12/22/15 (Delivered) |
08-04-2019, 04:12 PM | #8 |
It was the TQ converter and pump.
Who Dares...Wins |
08-04-2019, 06:09 PM | #9 |
What did you end up replacing the TQ converter with (stock or aftermarket)? Glad to hear you’re back up and running.
08-04-2019, 10:41 PM | #10 |
Thanks man. Stock replace and all covered by GM. The car is sold...
Who Dares...Wins |
09-07-2019, 01:25 PM | #11 |
Drives: like an old lady Join Date: Jun 2012
that escalated quickly.
2016+ camaro: everyone’s first car
10-09-2019, 04:05 PM | #12 |
Drives: Chevy Camaro Join Date: May 2019
