09-24-2021, 04:10 PM | #15 |
Can you see if the blend door is moving under the dash? It could be a wiring issue for the controls.
09-25-2021, 02:01 AM | #16 | |
Drives: 2010 LS Join Date: Feb 2021
decided to type an anecdote? When the door BREAKS, it falls down on an angle, OR will completely fall inside the box. Thus, you get the hot from the core, and whatever the outside air is. Turn the A/C on, you now have cold and hot air mixing in that box. It's a always on BLEND, not hot nor cold. I mean, there are a shit load of You Tube videos, and you come up with this as your best? You should have looked it up before your anecdotal reply... |
09-25-2021, 11:30 AM | #17 | |
09-25-2021, 02:07 PM | #18 |
Or if what your even saying is correct. I agree, chill out man.
ABM #2399 2SS/RS:SOLD
09-25-2021, 06:20 PM | #19 |
Fast Cars and Old Guitars
Wow, the only thing that creates more ire than a broken blend door, is discussing a broken blend door.
09-27-2021, 02:50 AM | #20 | |
you can just disagree blindly. When the door FALLS down, both the core and condenser are exposed. No matter what air you pull in, it will pass over BOTH of them. If the A/C is not on, then you get the warm air from the core, since it's not on 100% hot. IF the A/C is on, then you still get a mixture of the hot air from the core, and evaporator. IF the door should fall down on an angle, you're still going to have both of those exposed, but eventually, it will fall. The blend door, moves to the CORE side as you go cooler, so that when it covers the core, you're getting all cold air from outside or AC. COLD MAX is where it sheers off at the actuator. The door can't go any farther, but the actuator twists on the end at the motor, and it sheers off eventually. Now, it can stick there COLD for a time, but every time you get in the car, and power up, the actuator sweeps, and it will eventually fall down. Bumps and potholes, it will eventually fall down. If you can catch it cold when it breaks, and unplug the actuator, it may stay there. One good hit in a bump or pothole, repeatedly, it will still fall down into the box. Last edited by AlanRubin; 09-27-2021 at 02:47 PM. |
09-27-2021, 12:47 PM | #21 | |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
09-27-2021, 01:34 PM | #22 | |
old... I know it is evaporator, and STILL typed condenser, the HUGE one in front of the radiator... Wow... Watched the video again on how the door sweeps, and corrected that too. Last edited by AlanRubin; 09-27-2021 at 02:48 PM. |
09-27-2021, 07:53 PM | #23 |
Drives: 15SS Camaro Join Date: Dec 2020
You still have it wrong, the evap is in the frt the heater core is at a slant in the rear.
