07-13-2021, 11:05 AM | #1 |
1/4 mile estimate
Hey guys I'm thinking of going to the 1/4 mile drag strip and was wondering what do you think that I could run? I'm making 438rwhp and have the stock rear end and 305/20's BFG'S. All of my mods are in my signature. Thanks
07-13-2021, 09:35 PM | #2 |
Drives: Never just fly under the radar Join Date: Jul 2015
12.22
Old Skool |
07-14-2021, 04:31 AM | #3 |
I was hoping to be in the 11's but I guess that's not going to happen without drag radials you think?
07-14-2021, 04:42 AM | #4 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
Gonna need a tire and a converter to go 11s
07-14-2021, 11:42 AM | #5 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
I’d say 12.8. If you’re asking, probably 13’s til you figure it out. Street tires will definitely make it tough.
07-14-2021, 12:41 PM | #6 |
How much time do you think that I could knock off with drag radials? And if I did go with drag radials do I have to worry about breaking an axle? I just replaced them with oem ones.
07-14-2021, 05:49 PM | #7 |
Any rear suspension mods?
07-14-2021, 05:53 PM | #8 |
No not yet. But I am leaning towards changing out the rear sub frame bushings for the poly. What would you recommend?
07-14-2021, 06:16 PM | #9 |
Evil Genius of Chevrolet
Toe rods, trailing arms are a must if you get drag radials.
My guess is mid to high 12's
07-15-2021, 02:05 AM | #10 |
Should I do the toe rods and trailing arms instead of the bushings?
07-15-2021, 05:50 AM | #11 |
waiting at the tree
I agree.
The TQ Converter is worth 4-5 tenths with a good drag radial. Wheel hop is what breaks axles.
2010 2SS/RS A6 ZL1 Rims
07-15-2021, 06:17 AM | #12 |
I did all 3 and have no wheel hop. I also did delrin control arm bushings.
07-15-2021, 06:32 AM | #13 |
So would you point me in the right direction of best brands and parts needed for toe rods, trailing arms, control arm bushings, and subframe bushings? Thanks guys.
07-15-2021, 06:35 AM | #14 |
I have BMR trailing arms and Toe rods. I put in Detroit speed cradle bushings. And I believe the delrin control arm bushings were GM. But lots of good brands out there to pick from. Do some research.
