Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V6 LGX Engine, Exhaust, and Bolt-Ons
Old 03-27-2024, 12:02 PM   #1
DonM
Camaro #4
DonM's Avatar
Drives: 2017-Hyper Blue Metallic-2LTmanual
How hard is it to change Coolant Temp sensor?
I went to an appointment this morning, and when I came back out and started the car, the temperature gauge didn't register. So I flipped through the controls and couldn't get a digital reading on the DIC either - just two dashes (- -).
After a few miles, the check engine light came on. So I stopped at the parts store to have them pull the codes, and they found code P0128 (Engine Coolant Temp Below Thermostat Regulating Temperature) and the suggested fix was to replace the thermostat.
My issue is that if the thermostat was bad, shouldn't I STILL get a temp reading? So I'm thinking the coolant temp sensor is bad. So where is the stupid thing, and how difficult is it to switch out?
Don M
Supercharged LGX + 6 speed manual = FUN!!
DonM is offline   Reply With Quote
Old 03-27-2024, 08:13 PM   #2
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
Drives: 2021/18 (de-fresh) 3LT RS
There are a few different threads on this issue. The car is programmed to not display a coolant temperature when the issue occurs, so the lack of a temperature display is not a direct consequence of the underlying issue.
The Maverick is offline   Reply With Quote
