01-07-2015, 04:20 PM | #1 |
Drives: 2010 2SS/RS Camaro Join Date: Aug 2014
Removing Dash From 2010 Camaro Question?
Has anyone on the forum removed the entire dash from a 2010 or 2011 SS Camaro? I have googled this subject & had no help.
I am designing a gauge panel that will be located in the same location that the OEM center HVAC vent above the radio is located. On the 2010 & 2011 Camaro, the entire dash must be removed to gain access to the back side for removal of the vent. Any & all information will be greatly appreciated. All The Best, Orange 2010 Camaro |
01-07-2015, 05:14 PM | #2 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
Not easy and the panel is subject to cracking on the '10 Camaro. How about a plan B ?
01-07-2015, 05:15 PM | #3 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
Buy a 2012 would be a good plan B. Had my vent out in 20 min
Ryan
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
01-07-2015, 05:31 PM | #4 | |
Also, there will be no plan B in this case. I will get it done no matter how long it takes or how hard it is. I can work on the car 24-7, 7 days a week if need be! Failure is not an option! Again, any help will be greatly appreciated. Orange 2010 Camaro |
01-07-2015, 05:36 PM | #5 |
01-07-2015, 05:57 PM | #6 |
Drives: 2013 Cammed/LSA Conversion 1LE Join Date: Mar 2013
This might help! http://www.superchevy.com/how-to/int...th-gen-camaro/
"Livin' life in the fast lane, moving at the speed of light and I can't slow down, only got a gallon in the gas tank, but I'm at the finish line so I can't stop now"
01-07-2015, 06:06 PM | #7 |
Sold car...
Drives: 2010 Rally Yellow 2SS/RS #37115 Join Date: Oct 2009
It was not hard, had it out to put in HUD. Just a lot of bolts under dash and you'll need a hand getting out of car. Time consuming.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust. |
01-07-2015, 08:18 PM | #8 |
old school chevy rodder
you might be able to find some on it on gen5diy.com
01-07-2015, 08:19 PM | #9 | |
Thank you SO MUCH for taking the time to post the link of the dash removal instructions that are needed to install the heads -up display in a 2010 Camaro. That my friend, is what this forum is all about. After reading the dash removal instructions, I now know that I can remove the dash myself, to gain access to the back side of the center HVAC vent & install the custom billet gauge panel that I am designing for the 201 & 2011 Camaro! I can now finish the design work on the panel regarding the chassis mounting points as well as all the other physical dimensions for a perfect fit in the dash. What I forgot to mention is that I am building a 2010 SS Camaro to compete in auto-cross events & need the gauge panel at eye level in the dash for obvious reasons when running at high speeds. THANK YOU SO MUCH again for your help with the dash removal instructions. All The Best, Orange 2010 Camaro |
01-07-2015, 08:35 PM | #10 | |
Drives: 2010 RJT 2SS M6 Camaro Join Date: Feb 2011
You do realize that GM already makes a gauge panel that fits in the center AC vent, don't you? Its PN 22950679. It was developed for the COPO Camaro.
2010 RJT 2SS M6, Kooks Long Tubes, NPP Exhaust, CAI Cold Air w/Jannetty Scoop, RotoFab Washer Bottle, Elite Engineering Catch Can, MGW Shifter w/ZL1 Shaft and Knob, 2015 SS Sedan Steering Wheel and Air Bag, 2012 Heater Hose Conversion, 2012 Power Seat Conversion, RS Head Lights,Gen5DIY RS Conversion Harness, LED Fog Lamp Bulbs, Backup Camera Kit, NLP Spoiler, SLP Splitter, ZL1 Rockers and Diffuser, Color Matched Shark Fin, RS Roof Mouldings, Painted White Stripes, WCC LS3 Emblems, Heritage Grille and Blacked Out Tail Light Panel w/Retro SS Emblems, 416 RWHP, 411 RWT, Tuned by BlueCat.
02-14-2018, 07:58 PM | #11 |
I know this is an old thread, but does anyone know the dimension differences between the 10-11 and the 12-15 dash. I’m thinking of taking the whole dash out of my 2010 and replacing it with a 2012 dash so I can use the ZL1 suede dash panel. Just don’t know if it would like up different.
02-15-2018, 04:23 PM | #12 |
Drives: 2011 2SS/RS Camaro Join Date: Sep 2017
Not to be an ASS...but don't you still have to look down a little with the gauges mounted where the HVAC vent was. Mounted my important gauges in the pillar where they're always in plain sight & still get to enjoy my heater in the winter.
02-15-2018, 05:07 PM | #13 | |
Drives: 2019 SS 2019 mustang GT Join Date: Apr 2017
02-15-2018, 07:22 PM | #14 |
Drives: 11 camaro Join Date: Mar 2017
I put a 13 zl1 dash in my ‘11 ss no problems with fitment. Got a gen 5 diy harness for the hud. Just remember to use ur original gauge cluster. As far as electrical the airbag in the passenger side of the dash has a different style plug but the same 4 colored wires that’s in ur car, so u have to swap plugs.
2011 1SS/ Thompson mtrsprts 416,Katech rotate assembly and cnc ls3 heads. Ferrera st. valves,BTR 685 Spr. F1A Procharger,3.70 pulley on 12 rib.Holley aux fuel pump,ZL1 fp and fpcm,dual alky control,Vmax TB,DSX E-85 sensor, fic1300 inj.Lsxperts custom cam,melling OP,mishimoto dual pass HX, ARH 2" headers, MD 4l80e, FTI 3200 stall,3:73 zl1 cradle, BC coil overs ,pfadt sway bars, EBC brakes and slotted rotors: 843rwhp tuned by LSXPERTS
