05-09-2024, 09:09 AM | #43 | |
2016 NFG 1SS A8
05-09-2024, 12:29 PM | #44 | |
Trying to get over the hesitation from the TC. I'd use Launch control if I could ever figure out how to get the damn thing to work, every time I've tried all I did was spun the tires.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | LS MSD Plug Wire Set | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq
05-14-2024, 11:27 PM | #45 |
Will be going to the drag strip again this Wednesday. Test out the new tune, and try to work in a 2000-2200 rpm stall on launch.
Apparently my car was peaking on hp at about 525 hp, with the new tune I have the potential to peak at 600hp, and about 570-580 hp in 80 degree weather. Learned a lot about the data logs from this tuner that readjusted things for me. Such as the value of a high stall launch. Real time estimate of hp based on data logs. Either way: TCM retuned with higher rpm shift points, but still relative to the intake system. From what I gather the original tune might have been intended for an LS rather than an LT. There are differences that I learned from this tuner that sometimes can be difficult for LS tuners to tune the LT's. Also the recommended BTR cam settings were not set in the tune for some reason. That alone increased airflow. Those recommended settings for the BTR cam are now set in the new tune. Hopefully I can make something happen this Wednesday. Looks like there is rain in the morning, but the strip doesn't open until 3pm so we'll see.
