01-28-2023, 05:48 PM | #71 | |
Joe.G - I am 3 hours and 10 minutes from GPI.
01-29-2023, 01:47 AM | #72 |
Very nice and spacious facility. I didn't take any pix of the shop since they work on some customers grudge cars.
02-05-2023, 07:27 PM | #73 |
CFD xmember flanges are installed finally!
Oil pan drops will be cake now 😉 Took it back apart to prime and paint. Let the primer cure overnight and paint tomorrow. They take 7/16 bolts 1.5" long.
02-05-2023, 07:56 PM | #74 |
Previous owner of my 1LE installed LED front turn signals that had the wrong resistance and removed the bulbs from the side markers. I put new bulbs in and the flashers work properly now but noticed the front driver side marker didn't work. Checked the new bulb and it's good so I got my meter out. Sure enough one wire is open circuit. I went to the front bumper connection to see if I was still open there and got lucky! Anywho I now have to unpin the terminal so I can replace it. Instead of getting another terminal to crimp on the wire I had a jumper harness that I just unpinned one and solder connector in. Now it's good to go 😉
02-17-2023, 10:02 PM | #75 |
Rolled yesterday so the oil is changed and I'm sending a sample off to Blackstone Labs to get a health check.
03-06-2023, 10:54 AM | #76 |
Blackstone report
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X Last edited by Bo White; 03-06-2023 at 11:11 AM. |
03-06-2023, 11:29 AM | #77 |
Anthony S
This made me order a test kit. Hoping to also get a good report card as the Camaro is about to get some boost.
03-06-2023, 07:03 PM | #78 |
03-06-2023, 07:59 PM | #79 |
Full test is 45
03-01-2024, 04:30 PM | #80 |
47k miles front/rear. Not too shabby out of a "50,000" mile tire.....
Proper alignment goes a long way.
03-01-2024, 04:34 PM | #81 |
Went 275/40-315/35. Never liked the look of the factory 285s on the rear 20x11 wheels.
03-01-2024, 05:52 PM | #82 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
Very nice usage out of the old tires. New tires look great. Are you going to mod this one like your old one was?
03-01-2024, 09:46 PM | #83 |
Very similar yes
03-02-2024, 07:48 AM | #84 |
