01-22-2018, 09:52 AM | #1 |
Drives: 2016 Camaro 2SS M6 Join Date: Jan 2017
What is with the stock spark advance tables?
It looks like Hellen Keller tuned these cars—holy shit! Why is it so damn jagged? I've been working on a tune for my car (haven't flashed it yet), by adding the extra timing from the GMPP LT1 crate engine stock tune and smoothing things out. The result looks very similar to a 2016 Corvette LT1 stock tune. Did they purposely handicap the Camaro or something?
‘16 Camaro 2SS M6 - RotoFab CAI, Soler Performance TB, E85
8.102 @ 89.85 MPH (bone stock) |
01-22-2018, 03:54 PM | #2 | |
Ted.
www.jannettyracing.com
01-22-2018, 04:07 PM | #3 |
I am, but the other tables match (other than transmission stuff), and this jaggedness seems to only be present on the Camaro spark advance table. Even if there is a reason, it seems like some sloppy work if you ask me. Like they threw a bunch of numbers at the thing until something worked. I also don't see why Chevy would make two seperate tunes for the same engine—seems like it would make more sense financially to have just one tune. I'm just getting into this gen 5 stuff though...coming from LS1.
01-22-2018, 05:58 PM | #4 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I only wish I knew what they were thinking as well. You can also see all the inconsistencies in the WOT PE timing adder tables, between the Camaro LT1, corvette LT1, and truck engines sometimes they add timing when its richer and sometimes they subtract timing.
Its like the built the timing adder table in and then decided to subtract timing and do it with the adder table instead of the base table. If you look at a LT1 GMPP crate engine tune the timing is different as well. It makes you think they way HP tuners reverse engineered it something got lost in the translation somewhere between all the tables. I'm not sure when they actually calibrate the engines weather or not they are looking at smooth graphs or code. No matter what you think discontinuities don't make a good model for something physical in nature like an engine. The base table dosent seem to look so bad, except for it seems like they pulled a little too much timing at high rpms at full load. |
01-22-2018, 06:21 PM | #5 | |
01-22-2018, 06:53 PM | #6 |
Drives: 16 camaro M6/ 18 ZL1 camaro A10 Join Date: Nov 2015
I'm not much of a tuner but I could see the spark curve is all over the place. I smoothed my spark graph out and added some timing but removed some timing down low rpms which allows me to pull off without it stalling out (M6). If you would like a copy of my tune please let me know and maybe you can compare it ( I don't know what version it is because I'm currently using 3.7 beta).
01-23-2018, 06:27 AM | #7 | |
01-23-2018, 11:44 AM | #8 |
Yes, I thought it seemed a lot stronger down low and up higher in the rpms. I can pull a pretty good hill in 6th at a 1k rpms and maintain speed which I couldn't do before. I also picked up about 1 mpg with less black tailpipes and with the changes I can run 89 octane most of the year without pinging which you will have to look at my spark tables and see if what you think for your car as to that. I will post a copy of my file when I get home on here so you can look at it and compare. Let me know what you think!
02-27-2018, 08:49 PM | #9 |
Drives: My Dad's car is a '16 1SS 6MT Join Date: Jul 2016
Hey did you end up posting the tune file.
03-23-2018, 08:33 PM | #10 |
03-25-2018, 04:26 PM | #11 |
The Mechanic
Drives: 1SS M Join Date: Dec 2017
03-25-2018, 04:53 PM | #12 |
03-26-2018, 08:39 AM | #13 |
The Mechanic
03-29-2018, 05:40 PM | #14 |
