04-30-2017, 02:34 AM | #1 |
Probably tired right now
Drives: 1Lap1LE | EV6 FE | 18 F150 Join Date: Sep 2010
Approx ceiling of fueling component...
Has anyone posted a list of approx whp limit (ballpark) with each component added to fuel system?
IE... whp limit for...
Obviously we can add combos... but I know if folks could do just the cam lob or just the lash cap for their needs - they'd stop there.
-Seven
'17 SS 1LE - 1LAP 1LE (Now with more 427!) '18 F150 Platinum Powerstroke diesel '22 Kia EV6 First Edition '18 RS3 (1 of 2) Cumulus Blue '24 911 T (ordered) Formers... '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor Last edited by RideZX6R; 04-30-2017 at 07:53 PM. |
04-30-2017, 06:44 AM | #2 |
Drives: 2017 Camaro 1SS Join Date: Aug 2016
You forgot to mention the low pressure pump. The supply is the basis of your system and if it's not up to the task, then all of the parts you put on the engine are moot.
As far as lash cap, they should only be used to compensate for the lower base circle of an aftermarket camshaft's fuel lobe. If you stick 1 on with a normal cam lobe you are just preloading the hpfp. Guys have broken the high pressure pumps off the engine pulling this stunt. |
04-30-2017, 07:53 PM | #3 | |
-Seven
'17 SS 1LE - 1LAP 1LE (Now with more 427!) '18 F150 Platinum Powerstroke diesel '22 Kia EV6 First Edition '18 RS3 (1 of 2) Cumulus Blue '24 911 T (ordered) Formers... '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor |
04-30-2017, 08:22 PM | #4 |
Drives: 2016 Camaro 2SS M6 Join Date: Mar 2017
Those are a set of tough questions there
Interested to see the answers also
715whp/665tq
04-30-2017, 09:06 PM | #5 |
Drives: '17 ZL1 Join Date: Jul 2016
This doesn't answer all of your questions, but I do have some related experience.
- I made over 600 RWHP and 650 RWTQ on a stock SS fuel low-pressure pump and an LT4 crate engine. The low-pressure pump never even came close to having a problem (logged with HP tuners). - The stock LT1 high-pressure system taps out at about 600 RWHP. That's why you see the guys with LT1 and an LT4 supercharger underdrive the supercharger a little bit. - The LT4 high-pressure system is good for at least 700 RWHP. |
04-30-2017, 09:54 PM | #6 |
Drives: C7 Z06 manual, 18 Zl1 manual, etc Join Date: Dec 2013
I am using the lt4 hpfp, 2017 Zl1 lpfp, lt4 injectors, and aftermarket cam to help out as well. I should know where this taps out tomorrow or day after (at a new shop and tuner). I am also running a 2.38 upper and 9.0 lower ud pulley system.
05-03-2017, 10:14 AM | #7 | |
Dyno Show Queen LOL
Buddy has a Zl1 his road to modification are as follows... might help w some info..
Zl1 baseline dyno 551 to the wheels stock psi ZL1 tune, 1 dwn smaller pulley, and headers 580 on 93 and 630 on e77 out of fuel high side ZL1 Cam added with better fuel lobe 685 8# e77 ZL1 w all above meth 725 13# e77 The low side is requiring a aux pump now... to go further.. this was a race with my friend he was on ZL1 w tune, 1 dwn smaller pulley, e85/e77 when he was stock vs me the Eforce has the advantage.. I doubt it would be close now he can keep up with my TT now.
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber Last edited by EDFHOBBIES; 05-03-2017 at 10:29 AM. |
05-04-2017, 10:15 AM | #8 |
Drives: Many C7's Join Date: Apr 2014
Filled in my .02
You would need to do a combo like.... Upgraded LPFP (or BAP) and LT4 HPFP Then you will have full fuel pressure on the low side, and plenty on the highside. Until you run out of LT4 HPFP..... Then comes your next steps. But again, as I have stated each car/truck is different. Some run out of LPFP first, others run out of HPFP first. Its best to take it to a tuner that knows them inside and out, and purchase parts for what YOUR car needs. (Unless you just wanna throw it all at it, but thats kinda pricy) |
05-04-2017, 10:18 AM | #9 | |
I have made 732 rwhp before it ran out. (procharged) But then a few months later one ran out at 666 rwhp (not kidding on the number, and it was roots blown) Because it had a HPFP that just wants as good as the last LT4 HPFP. So I would say the range that I have personally seen in 666rwhp-732rwhp |
05-06-2017, 01:12 AM | #10 | |
For my personal car... heads/cam/E85 is probably the name of the game. However it'll be a little odd, 5.3L Gen5 ported heads and then a specifically matched cam. Ideally the velocity the 5.3L heads will create should make the mid-range more powerful than 6.2L ported heads, but both would make similar power at high RPM. (basically the theory some folks have, myself included is that 6.2L heads might be a bit too big at lower rpms for anything other the FI applications, which I will not have - but realize this forum is the place to ask fueling questions).
-Seven
05-06-2017, 06:55 AM | #11 | |
05-08-2017, 09:30 AM | #12 |
05-08-2017, 09:58 AM | #13 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
This is what I saw on my car. It has a twin turbo system so it will have slight differences than the superchargers.
I feel if you want to go much above 650 you really need to change the pistons and if I was swapping pistons I would reduce the compression ratio to allow more usable boost at pump gas octane levels.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
05-16-2017, 09:15 AM | #14 |
Drives: 2016 2SS Join Date: Jul 2016
Good read. Anyone care to comment on where they think a ZL1 in tank and 32% fuel lobe will be maxed out at with the stock LT1 injectors and High side pump?
2016 2SS. H/C SBE 1.37 60ft, 6.36@109.49, 9.97@136+. Nuff Said.
