07-07-2021, 11:58 AM | #1 |
Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
Replacement Brake Pads? OEM or Aftermarket
What replacement brake pads/rotors do you use?
Wondering if I should replace worn pads/rotors with another set of OEM, or go with aftermarket. I don't road race it or anything. Just "normal" driving with occasional spirited driving if you know what I mean. |
07-07-2021, 12:17 PM | #2 |
oem or powerstop z26 if you want less dust
07-08-2021, 06:39 AM | #3 |
I second the Powerstop Z26, do you have the brembo option?
07-08-2021, 08:10 AM | #4 |
Drives: "Kara Zor-El" 2017 2SS HBM Join Date: Jul 2014
I third the Powerstop Z26!
Lana? Lana? LANA! LAAANAAAA!!!! What? Dangerzoooooone. |
07-08-2021, 12:46 PM | #5 |
07-08-2021, 12:51 PM | #6 | |
just dont do the rotors they are trash and not needed go oem gm on those
07-08-2021, 09:25 PM | #7 |
Drives: 2018 Camaro Join Date: Apr 2021
07-09-2021, 07:51 AM | #8 |
The Mechanic
Drives: 1SS M Join Date: Dec 2017
Ive always defaulted to stop tech sports on my street cars. Probably same dust as stock, stronger initial bite and good for 1 track day. After that they glaze pretty bad
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
