01-22-2024, 08:22 AM | #1 |
Drives: 2015 2LT RS Camaro Join Date: Jan 2013
2015 Camaro - is there a drain plug underneath the battery?
Subject essentially says it, but if there's water in your trunk is there a drain plug underneath the battery in the trunk?
This question comes from a series of unfortunate events. My sunroof drain tube disconnected, leaked into the trunk. I fixed the drain tube, put a tub of Damp-Rid in the back. The Damp-Rid tub broke/exploded and the liquid saturated the trunk. I cleaned all that up, but the residue of the Damp-Rid has accumulated more liquid in the trunk. I'd like to remove everything from the trunk, spray it down with cleaner and wash it, but I want to be sure there's a drain tube for the water I'm washing it with. Courtesy pic of my battery sitting in milky white water. Sent from my SM-S918U1 using Tapatalk |
01-22-2024, 08:34 AM | #2 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
There are body plugs under it that can be removed to let the water drain.
01-22-2024, 09:04 AM | #3 |
01-22-2024, 09:12 AM | #4 |
Yes there is. I had to clean mine out after my old battery puked in the trunk!!
