09-07-2023, 08:06 AM | #1 |
Drives: 2014 2SS/RS/1LE Join Date: Mar 2015
Rear Sway Bar End Links
How hard is it to change these? Mine is missing a bushing on each one and the other bushings are dry rotted. I'm replacing them with OEM end links unless someone else recommends a better aftermarket one that isn't too expensive. If anyone can post pictures on what needs to be done or an article Id appreciate it. I tried searching but I keep getting a page not found error every time I do a search. I'm pretty sure I can figure out how to do it but it always helps to have some guidance.
09-09-2023, 09:02 AM | #2 | |
Tri-County Camaro SWFL
09-09-2023, 09:25 AM | #3 | |
https://www.moog-suspension-parts.com/moog-k700542_rear |
09-09-2023, 12:40 PM | #4 |
Drives: 2015 BLCK 2SS/RS 1LE Join Date: Aug 2015
When I removed my rear end links to replace my stock 1LE shocks with Bilsteins I noticed there was some rust hidden underneath the bushings and the bushings had started to crack. I reassembled and finished suspension job but I later ordered new stock replacement end links from Rockauto and replaced on jack stands with not problem. I had also looked at the Moog but not sure you actually get much additional benefit so I stuck with OEM. Hardest part of replacement was keeping end link shafts from spinning while removing top nuts, have to hold bottom bolt head really tight with a box end wrench on bottom while removing top nut (I used a medium torque cordless impact).
2015 Black 1LE, COMP 54-454-11 Camshaft, Johnson short travel lifters, BTR .660 dual vlv springs, COMP Max-Lift BSR Shaft Rockers, CAI intake, APEX racing scoop/washer reloc kit, FAST 102 LSXR intake ported by Vengeance Racing, Nick Williams 102mm TB, GM Perf CNC ported heads, Stainless Power Long Tube headers, Fluidampr 25% underdrive balancer, Elite E2 catch can, dynotuned by DTP Racing 525 RWHP/495 TQ, Ghosted Oracle sidemarkers
