Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 4th Generation Camaros
Old 05-09-2015, 09:16 PM   #1
cliffdog89
cliffdog89's Avatar
Drives: 2LT/RS M6 '12 Camaro
94 3.4L V6 whine when accelerating - stops at highway speeds
I my brother has a 94 3.4L V6. When accelerating there is a whine coming from the front of the vehicle. Once you reach highway speeds and stop accelerating the whine goes away.
Any thoughts?
cliffdog89 is offline   Reply With Quote
Old 05-10-2015, 11:11 AM   #2
roorback
Drives: V8 permagrin
Check the Idler pulley. It's a common issue. Might fix your problem.
roorback is offline   Reply With Quote
Old 05-10-2015, 03:28 PM   #3
VASCAR2
VASCAR2's Avatar
Drives: 94 Camaro, 10 1LT IBM Camaro
If it is a manual 5 speed check the transmission fluid. Ours was low, drained fluid and filled the transmission with new fluid, noise went away.
VASCAR2 is offline   Reply With Quote
Old 05-12-2015, 05:56 AM   #4
cliffdog89
cliffdog89's Avatar
This is on my list of things to change. Thanks!
Old 05-12-2015, 05:57 AM   #5
cliffdog89
cliffdog89's Avatar
It's the automatic but I'm planning on changing the fluid in the anyways. Thanks!
Old 05-24-2015, 01:00 PM   #6
94tagt
Drives: Pontiac Trans Am
Is the air conditioning on or off?
94tagt is offline   Reply With Quote
Old 05-25-2015, 12:31 AM   #7
cliffdog89
cliffdog89's Avatar
Off
Old 05-25-2015, 12:34 AM   #8
cliffdog89
cliffdog89's Avatar
So I tried the idle arm/pulley assembly with no improvement . Next I'm trying the belt which I don't think is the problem but it is the cheapest item to replace. I'll be changing the trans fluid and filter as well. If there is no luck with that I'll probably be swapping the alternator.
