#1 |
![]() Drives: 2015 2LT RS Camaro Join Date: Jan 2013
Can the dealer install a back-up camera
... in my 1LT?
I didn't think I would need it but my wife bought a car with it installed and I think it's spectacular. |
#2 |
![]() ![]() ![]() ![]() Drives: 2012 1SS LS3 M6 black on black :) Join Date: May 2012
Don't know about the dealer but there are after market back up cameras if the dealer can't. Probably be too expensive to have a dealer do it.
#3 |
![]() Drives: camaro 2013 1lt Join Date: Oct 2012
in my 2013 1lt i talked to the dealer he said noway and said they dont even have the kit to doit . maybe somebody can but not thro the dealer
#4 |
Yeah that's what i figured. I've seen the kits on the DIY site but they feed through the rear view mirror and I have a frameless rear view mirror that I'm quite fond of.
#5 |
Russ
You may want to buy from a Camaro5 vendor. I haven't decided if I am going to buy a new head unit that has a camera input or buy the rear view camera. If I don't go with the new head unit I will buy the rear view mirror unit for sure.
Check out this link: http://www.gen5diy.com/?utm_source=c...ign=Gen5%2BDIY Russ |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 LT1/22 Colorado TB/69 Chevelle Join Date: Jun 2006
Since you have a 1LT with MyLink, I'm pretty sure all you will need is the camera, bracket for the rear bumper and the wiring. The Mylink radio in your car should display the camera image once it's hooked up but it might need to be programmed.
#7 |
Drives: 2010 Camaro 2SS/RS Join Date: Apr 2008
Doesn't the BCM need a flash to make it work?
#8 |
Drives: Car Join Date: Jan 2010
camera
My chevy dealer installed ofer's backup camera for me.
#9 |
COTW 12/3/12
Drives: 2012 Ashen Gray ZL1 Join Date: Aug 2011
I bought the reverse kit from Ofer (2SSRS) and owner of gen5diy.com for my 2011 SS and the install was really easy. About 90 minutes start to finish. I wouldn't even want to know what a dealer would charge to install it. I don't know how different the 2013's are, but I would bet that Ofer could help you out.
#10 |
knows 2 facts about ducks
Drives: ...and they're both wrong Join Date: Aug 2009
Possibly - but the dealer can do that easily. I just wouldn't pay their ridiculous hourly fee to install the camera.
#11 |
![]() ![]() Drives: '19 ZL1 1LE Join Date: Dec 2012
Looks like the gen5diy.com's camera is $460. That's probably a little too much for my current budget. Are there cheaper options out there?
#12 |
send a PM to 2SSRS - the $460 includes the cost of the new rearview mirror. Which you wouldn't need. So you'd probably be able to get the kit for a decent bit cheaper.
#13 |
Oh., I thought I would need a camera on my 2011..
#14 |
COTW 12/3/12
For the 2011 you will need the camera and mirror, but it's a simple plug and play with the only permanent modification being the installation of the camera.
There might be cheaper options out there, but if you want it to look OEM, Ofer's kit is the way to go. |
