Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > Wheels | Tires | Suspension | Brakes
Old 03-27-2014, 03:43 PM   #1
1FASTC7
1FASTC7's Avatar
Drives: 2014 Corvette Stingray
Racing Tires
The stock Michelin tires grip good. However, does anyone know if the cup tires or better are available for the stock z51 rims?
1FASTC7 is offline   Reply With Quote
Old 04-05-2014, 05:02 PM   #2
C7Driver
C7Driver's Avatar
Drives: 2014 Z51 Lime Rock Green
I doubt if you will find a better tire, for the track, that fit the stock Z51 rims than the Michelin Super Sport Summer tires that come with the car. Just have to remember they are Summer tires and don't like cold temps. There are several on-line tire reviews that give this tire very good marks.
Some folks have swapped them out for the Michelin All Season 3 tires but they have no plans to track their cars and wanted a tire with a better wear factor. The A/S 3 tires are NOT run flats so keep that in mind.
Hope this helps.
C7Driver is offline   Reply With Quote
Old 04-07-2014, 07:38 AM   #3
Searious
Searious's Avatar
Drives: Crystal Red C7 2LT Z51
I've been looking around quite a bit - maybe the Proxes R888. 285/35ZR20 in rear, 245/35ZR19 in front. They're R-Comps and I would be fairly sure they would outperform the PSS. Doesn't look like the wider tires will fit on stock rims per Toyo's specs. No testing or concrete data on my part, just going off R-Comps normally outperforming anything else (despite how good the stock tires are). Not run-flats, of course.
C7 Status:
1100 - 2/10/14
3000 - 2/12/14
TPW - 3/17/14
Born - 3/20/14
R8C - Pickup on 4/3/14!
Searious is offline   Reply With Quote
Old 04-07-2014, 08:00 AM   #4
kalimus
kalimus's Avatar
Drives: '14 Z51 3LT Stingray and '13 Cruze
At what temperatures do the stock tires perform the best? I was driving the other day with temps in the mid-to-high 60's, and they still break loose a bit under WOT at around 5k RPM. Is that normal?
"We have a mental health problem disguised as a gun problem, and a tyranny problem disguised as a security problem."
"What is a moderate interpretation of the text? Halfway between what it really means and what you'd like it to mean?" -Antonin Scalia
kalimus is offline   Reply With Quote
Old 04-07-2014, 10:56 AM   #5
Searious
Searious's Avatar
The real question is what the tire temp was. When autocrossing I normally want as much heat as possible in my tires (note: this is for the M Roadster I run while I break in the C7) and don't spray them down to cool until they're close to 120°F+. Some tires are best at even higher temps. Since the C7 just displays "warm", I would take a temp gun to them and see how it acts at different temps. Even at ideal temp, this car has enough torque to break any tire loose if you really push it!
C7 Status:
1100 - 2/10/14
3000 - 2/12/14
TPW - 3/17/14
Born - 3/20/14
Old 05-05-2014, 09:56 PM   #6
GQ4Life
Drives: 2010 Camaro SS LS3
PSS like heat. At track once warmed good. A lap or two they really grabbed. I forgot to take temp so only temp I have is after sitting in the put awhile. Was 110°
I'd call michelin for exact range but I'd guess one you get over 120° they start to get real sticky but keep under 200 I would think.. I'll Google
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 05-06-2014, 11:00 AM   #7
gthal
gthal's Avatar
Drives: 2014 Z51 coupe
Agreed... most high performance tires REALLY need a lot of heat to grip well. Driving to Walmart and back won't do it either On a warm day, take the car for a 15 minute spirited drive to get the tires up to temp and they'll grip a ton then.
Keep in mind, however, that even the grippiest tires will break loose with 465 ft/lbs of torque. The tire can't overcome physics
Current: 2014 Z51 | Torch red | Black interior
Previous: 2012 C63 AMG coupe | Obsidian black | Red/black interior | Performance Package
Previous:
1996 BMW M3 | Estoril blue | Track car | Heavily modded for the track but still street legal... barely
Previous: 2011 M3 coupe | Jerez black | Fox Red interior | Competition Package | M-DCT
gthal is offline   Reply With Quote
Old 05-07-2014, 07:23 AM   #8
Searious
Searious's Avatar
Well, I suppose you could fill the back of the car with bags of concrete. F=µmg and all that...too bad it's also a=F/m. Darn physics keeps trying to slow us down!
C7 Status:
1100 - 2/10/14
3000 - 2/12/14
TPW - 3/17/14
Born - 3/20/14
Old 06-12-2014, 01:07 AM   #9
GQ4Life
wish they made a stickie tire like pilot cups, or r888 or a048 but with more tread for the rain
