Roto-Fab
Old 07-31-2011, 12:03 PM   #1
Ohten
Ohten's Avatar
Drives: Granite Crystal Challenger SRT
CEL heeeeelp
I have a Vararam intake and the clamp that holds the maf sensor harness to the radiator hose got loose and contacted my power steering pulley.Two wires were damaged,I have made repairs to the wires but still have a CEL.The codes are P2534 and P069E,does any one have a clue as to what these are and how to correct it.
I have tried disconnecting the battery and still have them.Also car runs like crap.
Ohten is offline   Reply With Quote
Old 07-31-2011, 12:36 PM   #2
bmorecam
Drives: jealous vendors mad!! HAHA!!
Press your onstar button and ask them what does the code come back as and they will tell you. Post back and let us know what the code refers to.
bmorecam is offline   Reply With Quote
Old 07-31-2011, 12:56 PM   #3
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
codes will not clear just from disconnecting the battery,, you need a scan tool, also there is a 12v power wire in the maf harness, you may have blown the fuse that powers the maf (under hood fuse block, fuse #14, should be a 7.5 amp fuse)
415ci stroker, TVS 2300 Magnacharger, cnc heads, cam, yank ss3200 converter, Kooks long tubes, Bwoody true cold air kit, ZL1 Pump, magnaflow 3" cat-back, lowering springs,BMR control arms and tie rod bars, 3.73 gears, diff mounts, RX can, ADM fuel controller
camaro1 is offline   Reply With Quote
Old 07-31-2011, 01:05 PM   #4
cowboy1948
cowboy1948's Avatar
Drives: 10 LT2/RS-08 SILVERADO-05 COBALT
Cool
Code P2534 means, Ignition 1 switch circuit low voatage.
Code P069E means, Fuel pump control mdule requisted MIL illumination.
Is this a V6 or V8.
Retired
cowboy1948 is offline   Reply With Quote
Old 07-31-2011, 02:19 PM   #5
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
Is this a V6 or V8.
I think his sig says V8.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 07-31-2011, 02:33 PM   #6
Ohten
Ohten's Avatar
Going to check fuse,thanks.
Old 07-31-2011, 02:34 PM   #7
Ohten
Ohten's Avatar
Is this a V6 or V8.
V8-L99
Old 07-31-2011, 02:45 PM   #8
Ohten
Ohten's Avatar
Replaced fuse,cleared codes w/SCT scanner,CEL is gone.You guys are the greatest.
Thanks.
Old 08-30-2011, 03:28 PM   #9
Z28Taxman
Drives: Black 99 Z28 Black '10 SS/RS
I just had mine in the shop for those exact 2 codes. Turned out to be a short that blew a fuse.
It also caused a code for skip shift low voltage and caused the reverse lockout to lock me out of reverse.
Warrantee took care of it and we're back, good as new!
99 Black Z28
'10 Black 2SS/RS on order 7/3/09, Delivered 9/21
Z28Taxman is offline   Reply With Quote
Long tube's and CEL bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 26 03-09-2011 08:17 PM
Cure for the CEL ?! 5thGENv6 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 27 02-12-2011 07:13 AM
One possible solution to CEL P0430 w/ JBA midpipes Goliath Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 01-10-2011 07:55 PM
Another LT Headers and CEL for Emissions kauffjd3 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 10-29-2010 02:54 PM
Clearing a CEL jtzako 5th Gen Camaro SS LS LT General Discussions 8 07-09-2010 01:37 PM
