Old 01-11-2019, 08:10 PM   #1
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
LS7 small bore head dyno info
Found this surfing around, amazing results.
https://www.corvetteforum.com/forums...l#&gid=1&pid=1
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 01-11-2019, 08:46 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
It didn't think the MSD IM wouldn't work on a 5th Gen.
Orange Krush II
Old 01-11-2019, 08:56 PM   #3
zz430camaro
Drives: 2015 1LE
They put LS7 small bore heads on it, that is why it works.
Old 01-12-2019, 04:20 AM   #4
Bo White
Bo White's Avatar
correct
Old 01-12-2019, 07:09 AM   #5
zz430camaro
Drives: 2015 1LE
I have looked at several torque curves for these combos and think its intereting to see their shape. Although the LS7 head is good its runner cross section is not that far off from the LS3. The torque at high rpm must be from the intake manifold being tuned for a higher rev range and a decent size cam.
Old 01-12-2019, 10:38 AM   #6
383z
Drives: 1993 Camaro Z28
You are right on the money. GPI said the same thing about their MAX Package.
They also said their LS7 heads have are 12 degree angle which helps with a bigger cam.
I wonder what's the TSP PRC small bored LS7 heads angle? I'll have to look it up.
https://gwatneyperformance.com/produ...d-cam-package/
383z is offline   Reply With Quote
Old 01-13-2019, 07:47 AM   #7
christianchevell
old school chevy rodder
christianchevell's Avatar
I would think just like the GPI engine the results are even better with a stroker and the torque is what moves you.....add 50 ft lbs and more you feel it big time even more.....and with the 1.8 rockers on the heads the cams actually smaller yet is multiplied more by the rockers ratio. as in about .035 added on to say a .600 lift its now .635 due to the rockers if my memory does not fail me.
Old 01-18-2019, 04:43 PM   #8
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
If Im not mistaken small bores ls7 are just ls7 heads with smaller ex valves. They flow a lot!! Think the TSP version have some sort of CNC work into it.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 01-25-2019, 05:38 PM   #9
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '11 2SS/RS IBM/BLK M6
Run the Mast Black Label 265 LS7 Heads here they work great with a Stroker.They have an 11 degree angle.
Old 01-26-2019, 09:47 PM   #10
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
So what's the difference in the LS3 MSD intake for a Vette that it won't fit in a Camaro without cowl trimming but a LS7 MSD will fit???
Orange Krush II
Old 01-27-2019, 06:57 PM   #11
KW Baraka
KW Baraka's Avatar
Drives: 2014 Chevy SS
AFAIK, there's no such thing as a LS3 MSD intake.
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4
2014 Chevy SS --- 429ci Hydraulic Roller LS3
KW Baraka is offline   Reply With Quote
Old 01-28-2019, 05:00 PM   #12
SSBUSDRVR
SSBUSDRVR's Avatar
Yes they gave it a go and didn’t get the Results. At least they didn’t try to sell people Snake Oil. Says a lot for how well the “stock” LS3 Intake does.
Customer on Corvette Page got this straight from MSD
“Unfortunately the Atomic Airforce intake for the LS3 was not put into production.* The initial design did not have a sufficient change in horsepower to allow it to go to production.”
MSD LLC
