Roto-Fab
Old 11-16-2018, 09:33 PM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
My Engine Build!
The SBE has seen enough of the boosted life and is ready to be forged. Here is a list of the internals I have put together and purchased. Let me know your thoughts!!
I am sticking to the stock LS3 cubic inches.
Power Adder
- •Magnuson Heartbeat Supercharger
Intake
- •Roto-Fab Big Gulp 5'' Intake
Throttle body/Snout
- • Nick Williams boosted 103mm
- • Nick Williams boosted 112MM!
- • ADM Custom 103mm Snout
Catch can
- • Prospeed ZL1 Catch can (Powdercoated Black) With LSA vavle covers
Engine Build
- •LSR-SD2X 9.240" Deck Height with Dual Crossbolted Main Caps short block
- •AFR Mongoose Heads Upgraded Exhaust Valve to Inconel
- •Callie’s Dragon Slayer Crank #APH31T-DS58
- •Callie’s Ultra I beam Rods #U17175
- •Weisco pistons #10-K398X7
- •Weisco Piston wrist pin #10-S718
- •BTR Stage 4 PD Cam
- •Johnson Lifters #2116LSR
- •ARP Main Studs (To Support Dual Cross-bolted Main)
- •ARP Head Studs (6 Bolt)
- •Cometic Head Gaskets
- •Hinson C5-R Timing Chain
- •Clevite Main Bearings
- •Clevite Rod Bearings
- •BTR 3 Bolt Conversion
- •ACDELCO Header Gaskets #12617944
- •LSR Rear Main Seal
- •LSR Rear Main Cover Gasket
- •LSR Cam Thrust Plate
- •Timing Cover
- •Timing cover gasket #12633904
- •Oil Pan Gasket #12612350
- •Moroso Copo Oil Pan #MOR-21151
- •Melling 10296 Oil Pump
- •Front engine cover seal #296-02
- •ZL1/Z28 Engine mounts #20952437
- •NGK TR8ix
ADM LSA Conversion
- •ADM AC Bracket
- •ADM Alternator bracket
- •ADM Power steering Relocation bracket
- •Lsa Power steering pulley
- •Lsa Waterpump
- •Lsa Idler for 8 rib
- •Lsa Idlers for 8 rib
- •Lsa Tensioner
- •Lsa Tensioner bracket
- •ATI Dampner
- •Lpe 9.55" Ring
- •Griptec Blower Pulley
- •All Bolts and Belts
Fueling
- •Fore Camaro L4 Fuel system (Triple Pump)
- LSA/LS9 fore fuel rail
- Primary pump: TI AUTO 274
- Secondary Fuel Pumps 2x TI AUTO 285's
- FC3 Staged controller with 4 gauge wiring
- PTFE -10 feed & -10 Return
- Stainless filter media
- Billet mounting bracket
- Honeywell pressure switch for FC3
- All the other goodies
- •ID-1700's
Cooling Mods
- •Prospeed ZL1 Heat Exchanger (Upgraded to 1'' Barb's)
- •AFCO Race Radiator
- •Stewart EMP HX Pump
- •Roto-fab Res
Exhaust
- •Kooks 2'' Jet Hot coated With Catless Connections
- •ProFLow Exhaust Boost Cutouts
- •Solo Performance Resonators
- •Corsa ZL1 Black Tip Cat Back
Drivetrain/Wheels & Tires
- •Built TR6060
- •Mcleod Twin Disk
- •DSS One piece Drive Shaft
- •ZL1 Diff
- •DSS 1400HP Axles
- •Z/28 Wheel Hub/bearings
- •Carlyle 15” rear conversion kit
- •Weld S71’s Beadlocked
- •Mickey Thompson Pro’s 275/60/15
Break-in Oil
BR40 Driven Racing
Maintenance Oil (Every 3k miles or 3 months which ever comes first)
DT40 Driven Racing
Nighthawk89 is offline   Reply With Quote
Old 11-20-2018, 08:12 AM   #2
1fast
8.60 @ 157 @ 4200lbs
1fast's Avatar
Drives: 2010 Gen 5
Originally Posted by Nighthawk89 View Post
The SBE has seen enough of the boosted life and is ready to be forged. Here is a list of the internals I have put together. Let me know your thoughts!!
I am stick to the stock LS3 cubic inches.Head will also be upgraded.
-Headstuds ARP #234-5608
-Main Studs ARP #234-4317
-LS9 Head Gaskets #12622033
-Callies Dragon Slayer Crank #APH31T-DS58
-Johnson 2110R lifters
-Oil Pan Gasket #12612350
-Rear Engine Cover and Main Seal Set
-Timing Cover Set
-Clevite Main Bearing set #171-MS-2199H
-Clevite Rod Bearings #171-CB663P
-Callies 6.125 H beam connecting rods #U16300
-Weisco pistons #10-K398X7 (-3.2cc Flat-Top)
-Weisco Piston wrist pin #10-S718
I would leave the factory heads ons. Upgrade the valves to manely do not port. Im running 9.4 at 149 mph 19lbs boost 5 years no issues.
1fast is offline   Reply With Quote
Old 11-20-2018, 10:14 AM   #3
christianchevell
old school chevy rodder
christianchevell's Avatar
Frankly I would just buy a short block 419 from Livernois and be done with it, by the time you add all those parts together and the machining and such on your old block which can only be overhoned .020..... the five grand for a full forged stroked new block is cheap unless your the machinist. Just IMO..... and you can get the pistons for the right compression right off the bat, and the deal is you will gain torque, not just a rebuild. Then you can sell off your stocker. Be sure to get rings for boost along with the pistons, no ones going check everything for you on your parts list, you are your only person watching your back. Good Luck. BTW I use racetec http://racetecpistons.com/
and used Molnar whose "names" are so varied..as in wiseco etc....callies etc..... http://www.molnartechnologies.com/ The deal is I knew these guys decades ago by many names, the Racetec...yup its in Hunnington beach and the Guy was the Owner of JE pistons...……..the largest in the world piston maker...he got tired of freezing in Michigan and retired then got bored. Stuff I was recommended by well...a Machinist I trust named Jerry who just happens to sell stroker LS and other engines for custom engine supply/SAG performance..which would be about the largest maker of engines for sale on the internet I know of so by volume I have the most dependable most used reliable crap I could get...
I did lots of shopping a few years back.
Old 11-23-2018, 03:36 PM   #4
Nighthawk89
That may be what i decide on.. Or change over to LSA heads and call it a day..
Old 11-23-2018, 03:40 PM   #5
Nighthawk89
All of the parts have been ordered! Stay tuned for the arrival and engine build!
Old 11-25-2018, 02:06 PM   #6
Nighthawk89
Parts are arriving!
New Water pump (Existing is working fine but Figured while I’m in there)
Old 11-25-2018, 07:33 PM   #7
Nighthawk89
More parts!
Old 11-25-2018, 08:34 PM   #8
eLeSthree
Drives: 2011 Camaro SS 6sp
Just curious why you decided to stay with stock cubes? Once you pay for that Dragon Slayer crank, why not stroke it?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 11-25-2018, 11:34 PM   #9
Nighthawk89
Rather stay with stock cubes. Better suited for the Heartbeat blower sizing... If I was going to centri or twins then I Prbly would have...
Old 11-26-2018, 10:28 AM   #10
christianchevell
I painted my pulleys with like my intake some good Rustoleum silver outdoor BBQ paint I got at Home depot..old trick makes it look better IMO, a thought...……..
Old 11-26-2018, 11:05 AM   #11
Nighthawk89
I am going to likely do that as well. Clean things up a bit while it’s out! Looks clean Christian.
Old 11-26-2018, 09:08 PM   #12
eLeSthree
Ok I see. What is the heartbeat? 2.3? 2.4?
1158whp 1017wtq.
630whp 658wtq
Old 11-26-2018, 09:15 PM   #13
Nighthawk89
2.3. It’s not the largest of blowers by any means. But efficient.
Old 11-29-2018, 09:56 PM   #14
Nighthawk89
More Gaskets arriving!
build, streetcar
