Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 04-08-2022, 05:56 PM   #1
Whoomba
Drives: 2024Camaro 2SS CE Convertible
CAI and MAF
When you guys put a CAI on did you have to change the MAF? I was experimenting with one and the Idle g/s drops to about 1.8 and the idle is up and down.
Old 04-09-2022, 06:43 AM   #2
KillboyPowerhead
Drives: 2015 Z/22
No need to change a MAF sensor unless the amount of air the engine sucks in becomes more than the sensor can handle/is calibrated for. If the engine idles weird with the new intake, the ECU probably just needs time to adjust for the new air flow profile. Also make sure there are no leaks and everything is tight and seated properly. Which intake did you install? What size tube? Believe the factory tube is 3.25" diameter.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 04-10-2022, 02:48 PM   #3
Whoomba
It’s a modified oem z28. It’s 4 inches.
Old 04-12-2022, 09:01 PM   #4
Whoomba
After reading around the forum some guys have had a mild tune done to adjust for the CAI. I’ll get some before and after g/s and a/f numbers and see what you guys think.
Old 04-18-2022, 03:44 PM   #5
Lacpac
Lacpac's Avatar
Drives: 2012 Crystal Red Tintcoat RS
CAI, VMax Ported TB, no tune. Notice more pull at low RPM. I'm sure a tune would help more, just don't know who or where to go for one.
Lacpac is offline   Reply With Quote
Old 04-18-2022, 09:54 PM   #6
Whoomba
No ecm adjustment time for the cai?
Old 04-30-2022, 05:19 PM   #7
Whoomba
There’s got to be a cheaper way than dropping a grand on it.
