03-26-2019, 10:34 AM | #1 |
Drives: 2010 2SS/RS & 2007 2500HD D-Max Join Date: Dec 2014
Aluminum or steel flywheel? (L11-S clutch)
So i am looking to buy a monster here real soon and was wondering about input from people who have driven on the street with the lightweight aluminum flywheel? I autocross mainly with the car but it does go on a sunday cruise and to/from events. I can handle a little more RPM modulation from like stop lights and minimal stop/go traffic, any other woes people have experienced?
2010 Summit white SS/RS, Manzo full exhaust w/2" primaries, Roto-Fab intake, FE4 conversion, JRI Coilovers built by Ult_Performance w/hypercoils, BMR sway, BMR trailing arms, UMI toe links, solid sub-frame bushings, upper control arm bushings, radius inserts, caster locks, Taylor wires, BTR spec'd cam, tuned by ECS, various little lighting mods, ebay SLP splitter, Heritage grille, ZL1 rockers, Apex 19x11 w/RE-71r's 305/30/19, eaton tru-trac
2007 2500HD Duramax, Built trans, custom tuned beast |
03-26-2019, 12:33 PM | #2 |
Aluminum and dont look back
The thing they don't tell you is that clutch is heavier than the stock clutch on our cars. I think it's about 4-5 pounds heavier so their aluminum flywheel will offset the additional weight nicely. Currently I have a stock clutch with an aluminum Fidanza flywheel. I think it shaved about 10-12 pounds off and it's a nice improvement. I had to add some revs over stock to get moving but nothing crazy
2010 2SS/RS
03-27-2019, 09:06 AM | #3 |
any more unputs?
03-28-2019, 01:41 PM | #4 |
Drives: 14 ZL1 Join Date: Mar 2014
One note, both Monster flywheels are steel, one is just lightened by removing unnecessary material.
From your intended use, I would say go with the lightened flywheel. |
